Steering wheel play
Old Jul 10, 2014 | 07:39 AM
Tinbird83's Avatar
Tinbird83
Steering wheel play
I have a noticeable amount of slack in my steering wheel. I have replaced the tie rods, center link, gear box, rag joint. Just from a rookies view the slack looks May be in the top end.. Is there anything between the rag joint and steering wheel that I should be looking for? I'm frustrated with this for sure.
Old Jul 10, 2014 | 08:12 AM
Jklnhyd's Avatar
Jklnhyd
Could the splines on your steering wheel shaft be worn down? I have not heard of that before, but it's a guess.
If everything is new, and torqued down correctly, there shouldnt be that much play.
Maybe the knuckle at your gearbox, where it connects to the steering shaft is worn out.
Mustangking1's Avatar
Mustangking1
Did you replace your gear box with a Red-Head unit? If you did'nt that could be where your play is.
Old Jul 10, 2014 | 08:16 AM
redroad's Avatar
redroad
A rag joint even new is going to have a certain amount of slop in it .. Alternatives are
Borgeson Universal Company :: Ford Truck 1970-04 :: 70-'79 Full Size Ford Truck
Old Jul 10, 2014 | 09:11 AM
Tinbird83's Avatar
Tinbird83
Thanks for the reply. I will check the splines bc that sounds reasonable. The gear is a cardone, car quest brand. I'm suspicious of it now of course. I was going to get a redhead but needed/wanted something fast yada yada. I believe the rag joint is in good order. I tightened the hell out of all the bolts that came with kit from napa. I will investigate the top spline when I get home.
Old Jul 10, 2014 | 11:44 AM
Tinbird83's Avatar
Tinbird83
Steering slop
Has anyone ever heard of something from the rag joint back, as in towards the steering wheel, causing slop? Bearings? Etc
Old Jul 10, 2014 | 11:45 AM
Tinbird83's Avatar
Tinbird83
Excluding the splines
khammer
18
Aug 17, 2017 08:04 PM
Rachel Moody
15
Jan 16, 2017 11:51 AM
Sycostang67
23
Jan 18, 2010 09:42 PM
60RatRod
Sep 15, 2008 10:54 AM
kenmandoo2
Jun 29, 2005 04:26 PM
