Rust flaking off engine block
Old Mar 29, 2022 | 03:51 PM
Rebel2005's Avatar
Rebel2005
4th Gear
I have a 2005 6.0 ltr diesel with rust flaking off the block. Only suggestion from my mechanic is to flush it monthly or have it rebuilt. 247k miles pampered since I drove it off the lot in 2005. Just finding out that it should have been flushed every two years. Anyone else dealing with this or have suggestions?
Old Mar 29, 2022 | 07:30 PM
LindenBruce's Avatar
LindenBruce
Unless you are running straight water, you should not have rust in the cooling system. It's possibly casting sand, which some have had trouble with. But again, if you have flushed the cooling system in the past this should not be a problem. Have you ever done any cooling system maintenance? B.
Old Mar 29, 2022 | 08:43 PM
FishOnOne's Avatar
FishOnOne
You would think if your water jacket is rusty and flaking the oil cooler would be clogged.
Old Apr 6, 2022 | 09:26 AM
Rebel2005's Avatar
Rebel2005
4th Gear
I apologize for my delayed response. I am not running straight water. It always has the required amount of antifreeze. The cooler was replaced in 2012 when I did the EGR bypass. No other maintenance to the cooler or flushing has been done.
Old Apr 6, 2022 | 09:28 AM
Rebel2005's Avatar
Rebel2005
4th Gear
I apologize for my delayed response. My mechanic said he expects the cooler to fail in the near future due to the rust & clogging already occurring in the cooler.
Old Apr 8, 2022 | 01:30 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Maybe check engine grounds. Corrosion is an electro-chemical process. If no issues are found a sacrificial anode could slow things down a bit. It used to be common to hang one from the radiator cap.
Old Apr 8, 2022 | 02:23 PM
FiveOJester's Avatar
FiveOJester
If you only changed the coolant once since the truck was purchased new that would likely explain why you are having corrosion issues. I assume you are running the Ford Gold which I believe requires a replacement every 2-years maximum. It doesn't hold very well in this application.
Highly recommended to switch to a red ELC coolant. With a rusty block you'll want to flush it really thoroughly, and then change the oil cooler. Don't change it before the flush as you'll just plug up your new one with debris that you'll break loose during the flush.
Coolant filter likely a good idea as well to help try and catch some of the debris as well.
Regards,
Old Apr 8, 2022 | 03:29 PM
Old-Marine's Avatar
Old-Marine
That is some sage advise man.
gpf2ez
Oct 11, 2017 02:54 PM
hrvat
Jun 23, 2012 11:06 AM
SD F350 99
Oct 14, 2009 07:39 PM
Lee250
Dec 15, 2006 09:24 AM
