Engine Block Rust
Old Oct 11, 2009 | 06:49 PM
SD F350 99's Avatar
SD F350 99
Engine Block Rust
OK, did a search and didn't find anyone else mention this. I was under my truck today draining the water separator and look up at the engine block. There is an awful lot of rust scale on the drivers side right below the rear most soft plug on the engine block. Anybody else notice this on there truck. Wanted to check before I take it to the stealership.
Truck is an 05 6.0L.
Old Oct 11, 2009 | 07:09 PM
69cj's Avatar
69cj
Sounds like you have a soft plug leaking. If the coolant is up to snuff the rust is possibly external.
Old Oct 13, 2009 | 04:14 PM
SD F350 99's Avatar
SD F350 99
That was my first fear. Soft plugs are fine. Rust seems to be just external. I've just never seen an engine block flaking off big chunks of rust before and wasn't sure if this was a common problem or not.
Old Oct 13, 2009 | 05:30 PM
RoyC's Avatar
RoyC
Since you are in Ohio, the rust belt, I would not be surprised to see rust every where there is steel/iron on your truck.
Roy
Old Oct 13, 2009 | 06:06 PM
69cj's Avatar
69cj
Hit it with some scotchbrite and then some self etching primer.
Old Oct 14, 2009 | 06:39 PM
SD F350 99's Avatar
SD F350 99
yeah this rust belt is kicking my trucks a$#. I will try the scotchbrite and etch primer to help slow down the process. Guess that Caterpiller is looking better & better.
Old Oct 14, 2009 | 07:39 PM
69cj's Avatar
69cj
Cats will rust too. Metal is metal.
jeffgoll
Mar 20, 2025 12:43 PM
sanders92
1978 - 1996 Big Bronco
Sep 17, 2012 04:34 AM
MDSuperDuty
Modular V10 (6.8l)
19
Jan 22, 2012 07:49 AM
Piolet
Sep 10, 2011 07:33 PM
SD F350 99
Oct 2, 2010 09:03 AM
