Excursion compatibility for ball valve max ac mod?
Old Mar 27, 2022 | 12:22 PM
CousinCarl's Avatar
CousinCarl
Plastic heater valve is leaking in my Ex. Can I replace with a 3/4 manual ball valve like we do with our trucks without a factory valve and just cap the gray vacuum line?
Old Mar 27, 2022 | 12:42 PM
kd5zll's Avatar
kd5zll
If i understand the system correctly, the answer is yes.
but i dont think those valves are really much mosre costly than the ball valve...
Old Mar 27, 2022 | 10:22 PM
CousinCarl's Avatar
CousinCarl
Not worried about price. Just reliability and availability. Oem valve is 3hrs away in stock or a 3 day ship. Aftermarket valves are worthless. A trusty manual ball valve is local, cheap, and just about fail-safe - all appealing for a daily-driven Excursion. Was hoping someone had done it.
Old Mar 27, 2022 | 10:26 PM
kd5zll's Avatar
kd5zll
Well... i was reading about putting the vac valve in my SD, and from the discussion there, my understanding is the ex, and SD have the same system, except for that valve on the ex. Im actually putting in the ball valve on my SD, when i do my coolant flush and filter install. Bought the valve friday.
Old Mar 28, 2022 | 02:21 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I have no issues for several years with the basic 74809 valve available everywhere.
Hook it up so it works only on max AC so you can blend all the other HVAC settings.
The lazy convenience does come at the cost of simplicity.
Old Mar 28, 2022 | 02:37 AM
josht's Avatar
josht
What David said. I've been using the same basic valves in a Rangers for years. I've only ever had one fail, and it wasn't even a failure in use. I was replacing old coolant hoses on the 99 Ranger many years ago, when trying to separate the hose from the valve I managed to break off the nipple on the valve. Prior to that it was functioning fine and not leaking.
Old Mar 28, 2022 | 06:21 AM
CousinCarl's Avatar
CousinCarl
Excuse my ignorance of how the system flows/works. My Excursion oem valve has only 2 lines, an in/out on the valve.
The added gray vacuum line and excursion rear heat/ac controls that differ from my 350 are what I am not sure about regarding my ability to retain functionality if I change it up.
Old Mar 28, 2022 | 10:35 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I am in the same boat as David and Josht. I have been using the Ranger (very similar to the Excursion) valve for many years without fail. I know for a while people were having all sorts of problems with it leaking, but people only come here to complain sometimes. After a failed attempt to use the Diesel Site Max AC Assist dohicky, I installed the Ranger valve. Been great going on 5+ years now.
CousinCarl, your question is not a bad one. The valve you have does the same thing as the 4 port valve. Yours only cuts off one hose from flowing where the Ranger valve cuts off flow from both hoses. The Diesel Site valve only cuts off one hose too. A lot of people that install the PEX valve only cut off one hose, some do two.
Same result based on stopping coolant flow from or to the heater core.
Old Mar 28, 2022 | 10:56 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The OEM Excursion valve shown above is the same valve that Ford installed in pickup and chassis cab 7.3L Super Duties in 2002-2003.
It is different than the Ranger valve.
Old Mar 28, 2022 | 02:06 PM
brian42's Avatar
brian42
Veteran: Navy
Yes you can. That's what I did.
I went the "Ranger valve" and had both of them eventually leak on me. After that I went with the manual valve and never had any problems.
BBslider001
94
Jun 16, 2023 09:09 AM
Jaime74656
Jul 23, 2018 10:12 AM
ewpierce
Jul 16, 2018 12:48 PM
timmyboy76
20
Aug 27, 2011 12:04 AM
just another truck
39
Jul 6, 2011 09:01 AM
