Problem with dash voltage regulator
Old Jun 18, 2022 | 04:31 PM
lasermike's Avatar
lasermike
Using a 7805 is is dead simple. Connect the positive terminal from the old IVR to pin 1, connect pin 2 to ground and you'll have 5 volts on pin 3. Actually you do need to add a couple of capacitors to prevent oscillation and provide a more stable voltage. Plus a bit of heat sink wouldn't hurt.
This post has a ton of information about the IVR and how to convert it to solid state.
Michael
Hobb
Dec 12, 2018 10:14 AM
dreamofford
May 30, 2017 01:59 PM
friskyjake
1983 - 2012 Ranger & B-Series
May 17, 2011 06:01 PM
68f250429
Mar 30, 2004 07:55 PM
1970f2504x4
Electrical Systems/Wiring
Dec 9, 2001 04:30 PM
