Dash Gauges
Old Mar 25, 2004 | 09:34 PM
68f250429's Avatar
68f250429
Dash Gauges
My Dash Gauges Recently Quit Working. The Gas Gauge Was The Only One That Worked. I Hooked Up The Others And Now None Of Them Work? Any Help Would Be Helpful. Thank You. Beau
Old Mar 26, 2004 | 09:03 AM
talisker's Avatar
talisker
Do you have voltage coming out of the voltage regulator on the back of the instrument panel? It should be about 5 VDC. If there is no voltage then start working back from there. If there is voltage the problem is probably in the gas guage or the wiring or the sender.
Old Mar 26, 2004 | 08:30 PM
68f250429's Avatar
68f250429
it is not just the gas gauge that dosen't work,none of the gauges work. i checked for power coming in and out of the regulator with a test light and got nothing. so now what?
Old Mar 26, 2004 | 10:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
replace the regulator.
Old Mar 27, 2004 | 10:23 PM
WAExplorer's Avatar
WAExplorer
Don't replace the regulator yet. You need to find out where the power to the regulator comes from. Like the previous post, trace backwards till you find out why there is no power and fix it.
Old Mar 27, 2004 | 10:24 PM
Torque1st's Avatar
Torque1st
Posting Legend
Good catch, I didn't see the in and out part.
Old Mar 28, 2004 | 06:22 PM
68f250429's Avatar
68f250429
thanks for the help i had already replaced the regulator and still had no power coming out of the regulator. i did find two blown fuses under the hood. they are two seperate red wires with fuse holders on them. they apear to be original. one of them plugs into the main wiring harness that runs along the frame.any idea what these supply power to. the only gauge that has power is the alt. gauge but it dosen't any movement is this normal?
Old Mar 28, 2004 | 07:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have faced many trucks with "mystery wires" in them. Unless I can identify the purpose and whether it is working properly I jerk them out. I have cleaned up hundreds of rats nest wiring jobs. I strip it all back to the OEM harness and then start repairs.
Old Mar 29, 2004 | 09:48 PM
68f250429's Avatar
68f250429
the ignition side of the regulator has power but from what i can make of it on the wiring diagram the other side is a ground. does this sound right? thanks.beau
Old Mar 29, 2004 | 11:48 PM
Mil1ion's Avatar
Mil1ion
No , On the cluster (Plugged into the harness) with the key on.
Proble the instrument cluster voltage regulator .
You should measure 12 Volts going in & a pulsing 5 volts coming out.
Old Mar 30, 2004 | 12:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
The tab/case of the regulator is grounded for proper operation.
Old Mar 30, 2004 | 06:52 PM
68f250429's Avatar
68f250429
thanks i'll see what kind of voltage i have. if i do not have the specified voltage then what could cause the low or higher voltage?
Old Mar 30, 2004 | 07:55 PM
68f250429's Avatar
68f250429
i have twelve volts coming in but nothing coming out. what is causing this? i have tried two different regulators.
