icvr
Old May 16, 2011 | 06:37 PM
friskyjake's Avatar
friskyjake
icvr
is the insturment cluster voltage regulator attached to the back of the dash? I,m thinking this is whats making the dash lites dim & sometimes brighter? This is on a 87 ford ranger thanks.
Old May 17, 2011 | 03:23 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
The instrument voltage regulator reduces voltage to the instruments. If it fails, your gauges will peg. Mine use to do that and I would tap on the dash to make them come back to normal. I am not sure if the peanut bulbs are the same reduced voltage as the gauges.
Old May 17, 2011 | 06:01 PM
friskyjake's Avatar
friskyjake
It,s the lites that sometimes go dimmer & later will be normal. Real weird. I,m going to change it out. thank you.
JAYS 77 F-250
Feb 22, 2015 05:31 PM
drptop70ss
Nov 21, 2013 08:52 PM
desertwest
Nov 15, 2013 06:14 PM
Ripcity
Sep 30, 2013 07:36 PM
doublenot7
6.7L Power Stroke Diesel
Nov 17, 2011 10:25 AM
