constant voltage regulator
Old May 21, 2017 | 11:26 PM
dreamofford's Avatar
dreamofford
mine bit the dust and i haven't found a cheap one. i read somewhere someone made a homemade one for cheap,any info on this?
Old May 22, 2017 | 11:50 AM
smoky_diesel's Avatar
smoky_diesel
You can replace the bimetallic switcher (not constant voltage at all) with a cheap voltage regulator like a LM317. You would have to build the circuit although its only a few parts. The gauge system draws quite a bit of current.
Old May 22, 2017 | 01:26 PM
Tedster9's Avatar
Tedster9
How do you know it's bad?
Maybe you know this already, If measuring with a digital voltmeter it's going to look wonky. It's pretty choppy, since it's an averaging unit. It makes and breaks 12 volts a couple times a second mechanically, consequently "dropping" the average voltage the dash gauges see, they respond sluggish by design so everything works fine. They do go bad, but are often replaced unneccesarily. Try measuring with analog type meter, it's probably working fine.
Old May 22, 2017 | 02:36 PM
willowbilly3's Avatar
willowbilly3
define cheap. How expensive can a new one be?
Old May 22, 2017 | 04:28 PM
Tedster9's Avatar
Tedster9
They want $20 to $30 or so for the little charmers.
Old May 22, 2017 | 05:11 PM
ultraranger's Avatar
ultraranger
ICVR conversion.
IVR
Old May 27, 2017 | 01:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
ICVR: Instrument Cluster (Constant) Voltage Regulator
1967/69 use a different ICVR than 1970. 1971/72 is different again.
Old May 29, 2017 | 09:32 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
It would be a lot easier to buy one, but if you have hobby electronics skills, you can make one easily. I used junk-box items. If you make your own, you can add a transient protector across the leads, use better caps, and a better heat-sink.
Here is a picture of mine.
https://www.ford-trucks.com/forums/5...regulator.html
Still working.
Old May 30, 2017 | 01:59 PM
JEFFFAFA's Avatar
JEFFFAFA
67/69 F100/750 ICVR was part number C6DZ10804A.
Nos Parts Source *Fo
913.220.5746
Miller Obsolete Parts
Part Number:C6DZ-10804-A
Seller:Miller Obsolete Parts -
Description:REGULATOR GR-510
Phone (607) 722-5371
McDonald Obsolete Parts
Seller:McDonald Obsolete Parts -
Phone (812) 359-4965
Obsolete Reliable Parts
Seller:Obsolete Reliable Parts -
Description:REGULATOR, INST CLUSHTER VOLTAGE
Phone (229) 686-5101
fifty-two_f1
13
Aug 20, 2014 11:14 AM
jwtimme
Nov 24, 2011 02:57 AM
lgwitt
15
Aug 4, 2010 08:48 PM
adbecker
Oct 11, 2000 12:20 PM
