Instrument Voltage Regulator
Old Nov 16, 2001 | 11:50 PM
1970f2504x4's Avatar
1970f2504x4
Hello.. I am going to be replacing the voltage regulator in my truck this weekend (All my guages are dead and I think I narrowed it down to the IVR). I picked up a new one, but I can't figure out how to detach the old instrument voltage regulator from the plastic circuit board. My biggest fear is that I might break the plastic circuit board if I don't take it of the right way. What is the best way to get the circuit board detached from the IVR? Thanks!
James Kern
1970 F250 4x4
Old Nov 17, 2001 | 03:27 PM
nitro94's Avatar
nitro94
All of the ones I have changed have been attached to the back on the instrument cluster by one single screw.
Old Nov 17, 2001 | 08:29 PM
Mil1ion's Avatar
Mil1ion
All the ones I've seen are held by a nut !
Dennis
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Nov 17, 2001 | 10:36 PM
jbhf250's Avatar
jbhf250
Once the screw is removed ....It connects just like a 9 volt battery would
__JOHN__ô¿õ
1972 F-250
ICQ# 6030753
Old Nov 17, 2001 | 10:45 PM
BB's Avatar
BB
James, it connects the same way as the clip on a 9-volt battery. You're smart to be concerned about the flexible circuit board. Take a thin-bladed screwdriver and carefully pry apart the contacts each a little at a time and they will pop off. Be careful not to put any stress on the circuit board. The new one will snap back in, push straight down.
Barry.
Old Dec 6, 2001 | 08:07 PM
1970f2504x4
Well, I got it installed with no problem. I carefully pried off the snap connectors with a small screwdriver and it popped right off. It still didn't fix the guages, but at least I know that part is good. There isnn't alot left to diagnose in the circuit.. so I guess I should try replacing one of the sending units next.
James Kern
1970 F250 4x4
Old Dec 6, 2001 | 08:37 PM
kioolt's Avatar
kioolt
Have you checked for 12 volts at the input to the IVR. Also you should check the ground connections going to the dash gauges.
Old Dec 9, 2001 | 04:30 PM
milehiford's Avatar
milehiford
Post Instrument Voltage Regulator
kindorotten
24
Aug 21, 2016 10:18 AM
wtx66f100
Jul 30, 2014 08:17 PM
wtx66f100
Jul 27, 2014 02:07 PM
