Manual hubs?
Old Feb 26, 2022 | 02:21 PM
SgtNick_PSD's Avatar
SgtNick_PSD
Manual hubs?
Are there direct swap manual locking hubs out there for these trucks? I dislike the IWE system and its inevitable vacuum issues. I much prefer a stick-on-the-floor manual t-case too but oh well.
Old Mar 2, 2022 | 07:35 PM
wheelerfreak's Avatar
wheelerfreak
No. If the IWE does have any vacuum issues, the default is it locks.
Old Mar 2, 2022 | 07:45 PM
SgtNick_PSD
Bummer. Was hoping for manual lockers like my super duty.
Old Mar 3, 2022 | 08:43 AM
tbear853's Avatar
tbear853
I realize they can go south, but I don't think it's inevitable ... or even common. If ever it develops that one of mine starts loosing vacuum ... I'll pull and plug the lines from dirt and leave them fully engaged with no vacuum pulling on them until I can fix the thing leaking. Be sort of like leaving the hubs lock on my old truck.
Old Mar 31, 2022 | 11:30 PM
burndout's Avatar
burndout
I did this for too long and the slip on the front drive shaft wore out. I dont recommend it for extended periods.
Old Apr 1, 2022 | 08:55 AM
WWR's Avatar
WWR
Dorman makes drive pucks, but just yanking the vacuum lines at the knuckles has the same effect.
You can also install a vacuum switch in the cab and route the lines from the solenoid on the firewall instead to your switch, then YOU have manual control over vacuum. This would allow 2-lo for maneuvering trailers, etc.
My '07 XL has a manual t-case, I absolutely love it. Ford did an excellent job with the throw on the linkages, too - small, positive movements of the lever is all it takes to shift (unlike my '19 Wrangler which is comically pathetic)
kc7smo
Offroad & 4x4
35
Jul 8, 2024 03:18 PM
Bubba Jones
1978 - 1996 Big Bronco
Mar 31, 2016 10:28 AM
fordf350crazy
Mar 26, 2009 03:41 PM
orl87f150
Offroad & 4x4
Jan 26, 2004 09:00 AM
