Sponsored by: Real Truck
Manual and Automatic Locking Hubs
Old Mar 25, 2009 | 02:35 PM
fordf350crazy's Avatar
fordf350crazy
Has anyone coverted from manual locking hubs, to the auto and manual locking hubs? If so, what is all required?
Old Mar 25, 2009 | 02:43 PM
Downriver Thunder's Avatar
Downriver Thunder
Electrical, vacuum solenoid, vacuum lines, hubs, etc.
Old Mar 25, 2009 | 02:53 PM
fordf350crazy
Is it a big job, or even worth it?
Old Mar 25, 2009 | 03:16 PM
Cardiac69's Avatar
Cardiac69
Not worth it at all. Too many folks converting from the ESOF set up back to manual hubs. I replaced my hubs last fall with Mile Marker stainless manual hubs.
Old Mar 26, 2009 | 12:39 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
You'd also need a GEM to control the vacuum solenoid, and the switch in the dash, AND - the GEM won't engage the hubs until the transfer case is engaged, so you'd have to fool it into thinking it was, etc. etc.
Stick with what you have
Old Mar 26, 2009 | 01:20 PM
mikesmayhem's Avatar
mikesmayhem
I agree with the above posts. I converted mine form Auto to manual (WARN). I had vacuum issues that would not allow them to work properly.
Old Mar 26, 2009 | 02:05 PM
fordf350crazy
I need to replace my stock manual hubs. Which ones are the best? Warn? Mile Marker?
Old Mar 26, 2009 | 02:22 PM
mikesmayhem
I just had the WARN premiums installed last spring and they are great. My local 4X4 shop installed them for $50 because I bought from them. I did price shop and all the prices I found were the same so for $50 I said go for it.
Old Mar 26, 2009 | 02:52 PM
krewat's Avatar
krewat
I did the Warns, can't speak to the Mile Markers.
Check out our sponsors.
Old Mar 26, 2009 | 03:18 PM
da X-man's Avatar
da X-man
I personally don't have either of these, but if I were in the market, either would work. I've only heard good things about both.
Old Mar 26, 2009 | 03:41 PM
Cardiac69's Avatar
Cardiac69
I have the Mile Marker stainless hubs and they worked beautifully here in NW this past winter, and it was a brutal winter.....
Install them yourself...it only takes 5 minutes a side...
forddriver17
Jan 18, 2009 05:29 PM
Buckboard6-300
Dec 22, 2007 12:45 PM
plb150
Offroad & 4x4
Apr 9, 2004 09:48 AM
Irv
Jul 9, 2003 11:00 AM
roscoe
1978 - 1996 Big Bronco
Dec 7, 2000 12:52 PM
