Speedway front disc conversion
Old May 11, 2023 | 06:26 AM
  #46
turnrjr's Avatar
turnrjr
I drilled and tapped for a relocated grease fitting. Used a cobalt drill because the axle is very hard. I ended up pulling the kingpin in order to drill clean through because it wouldn’t take grease.
The relocating was necessary on mine as I wouldn’t have been able to connect the grease gun.
Old May 11, 2023 | 12:37 PM
  #47
JPMallory's Avatar
JPMallory
Originally Posted by Rembrant
I see in the instructions that one or more of the kingpin grease nipples may need to be relocated. After reading a few of these threads, I haven't seen where anybody actually had to do that.
Is that an issue still? I ordered the 5x5.5 kit, and I have a spare set of spindles I plan to use for some bench mock ups before installing on the truck.
I didn't have to relocate them on mine.
Old May 13, 2023 | 10:17 PM
  #48
tip49's Avatar
tip49
Flex lines
I have had the truck out a dozen times this year. I think I will lengthen front flex brake lines to create a bit more slack.
Old May 14, 2023 | 09:19 AM
  #49
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I've read that also, where some people might have to relocate the grease zerk and/or install a 90 degree zerk. I didn't have any issue on my 49. I've been involved in a couple of other conversions and we didn't have to change anything on them either.
It doesn't surprise me, these trucks were made in several different factories and I'm sure got parts from several different suppliers so there is bound to be differences.
Bobby
dmack91
35
Feb 19, 2022 10:39 PM
Whitey Ford
Feb 2, 2015 05:41 AM
Huntfamily53
13
Dec 2, 2011 04:33 PM
79 bronc
May 25, 2011 06:32 PM
imlowr2
May 14, 2005 11:14 AM
