Leaky front hub
Old Feb 17, 2022 | 07:55 AM
GV02's Avatar
GV02
Leaky front hub
Looks like I have a project when I get home. Any ideas what it might be. No smell, pretty dry, 4wd hub shifts freely and I have been using it alot.
Old Feb 17, 2022 | 08:43 AM
FordTruckNoob's Avatar
FordTruckNoob
Take lug nut cover off for a better pic.
Old Feb 17, 2022 | 09:58 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The hub lock/auto or lock/free mechanism has grease in it, not a fluid. So, I would not suspect that area as the failure point.
As FTN said, take the cover and possibly the wheel off. The on two fluids in that immediate area are the differential fluid and brake fluid. Since you have not experienced a failure in the service brakes, my primary suspect would be the differential fluid.
Other than that, you are looking at something from the engine bay, but it would have had to leak onto the axle tube or onto the hub (under the wheel) and make it's way under the cover.
Maybe a mouse got stuck in there and it is mouse **** and only requires some cleaning.
Old Feb 17, 2022 | 10:20 AM
SkySkiJason's Avatar
SkySkiJason
Make sure it’s not just excess grease from over zealous lubing of the axle bearing or unit bearing.
There isn’t really anything out there that can ‘leak’.
Old Feb 17, 2022 | 12:02 PM
GV02's Avatar
GV02
Thanks as always. Sounds like nothing catastrophic so I think I will limp it for the rest of the week until I make it back to FL.
Old Feb 17, 2022 | 02:45 PM
z31freakify's Avatar
z31freakify
You sure it's not ****? If it were grease it would of sling all over the wheel.
Old Feb 19, 2022 | 05:27 PM
GV02's Avatar
GV02
z31freakify, I think you are right. No more signs.
Old Feb 19, 2022 | 07:52 PM
Agate Flats's Avatar
Agate Flats
When we were kids, one of my buddies used to use the term "Breakdown Anxiety".
PLM1955
49
Sep 20, 2022 07:16 PM
Hyakkimaru
47
Feb 3, 2022 08:38 AM
Speedwagon98
Jul 28, 2021 04:43 AM
hdman6
Sep 11, 2008 01:38 PM
distortedcloud
Dec 19, 2007 10:15 PM
