Front hub ?
Old Sep 11, 2008 | 10:55 AM
hdman6's Avatar
hdman6
Question Front hub ?
I plan on installing a new front hub tommorrow. I have the stuff i need however i was wondering about the nut behind the 4x4 hub. Is that nut hard to get off and what did you use to remove it. I have the snap ring pliers, and the rest of the tools. Also what size are the 4 flange buts that hold the hub on? thanks Jeff
Old Sep 11, 2008 | 11:00 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Old Sep 11, 2008 | 11:12 AM
nhill2090's Avatar
nhill2090
Here is some torque specs. Don't know how much they will help but here is all the front end ones
cgl's Avatar
cgl
There is no nut behind the lock-out, only the snap ring. The hub assembly is held on by 4 studs/nuts. You get to them from the inside of the knuckle and they're 13/16 or 21MM. Which should be the same as the caliper bolts.
Old Sep 11, 2008 | 11:50 AM
jwhitetail's Avatar
jwhitetail
Those washers and the thing that looks like a nut are spacers, thake a magnet and get them out. You are replacing the unit bearing, make sure it comes with studs already installed. Let us know how it goes, it's not a hard job.
Old Sep 11, 2008 | 12:58 PM
BENG0924's Avatar
BENG0924
what is the difference on the unit bearing and the needle bearings that guzzles write up refers too.
Old Sep 11, 2008 | 01:38 PM
jwhitetail's Avatar
jwhitetail
The unit bearing is what is carring the load, and you can't rebuild it, just replace it , the needle bearing is on the back side of unit bearing and can be replaced. The needle bearing does nothing if you have lock out hubs, if your axle's are turning than the axles are turning inside the needle bearing. When locked in four wheel drive or if your axles won't set still in 2 wheel drive.
