Ambient air temperature sensor
Old Feb 10, 2022 | 01:05 PM
Pink mist's Avatar
Pink mist
How do you reset outside ambient air temperature sensor on 02 excursion 7.3 powerstroke already replaced sensor still reads 50 degrees no matter what the outside air temp is tried disconnecting batteries , pressing the ac and recirculating button didn't work
Old Feb 10, 2022 | 02:20 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
probably means there is a disconnect somewhere, maybe a short or a loose wire.
Old Feb 10, 2022 | 02:42 PM
kostkafex's Avatar
kostkafex
do you have the air temp in the HVAC and the overhead console? only one of those will actually work if you have both, usually the HVAC.
Old Feb 11, 2022 | 12:32 PM
bwguardian's Avatar
bwguardian
I have had that same issue and even sent the upper display off for rebuild...and still have the issue after replacing the sensor behind the grill on the driver side...
laserred
Aug 5, 2008 06:07 AM
BigDa
1997 - 2003 F150
Dec 1, 2006 11:53 PM
RobInAB
2004 - 2008 F150
Sep 6, 2006 07:59 AM
Mark250
Aug 17, 2005 12:37 PM
smittyranger1993
1983 - 2012 Ranger & B-Series
May 5, 2004 09:39 PM
