Ambient Air Temp Sensor
Old Sep 5, 2006 | 03:10 PM
RobInAB's Avatar
RobInAB
Hi all, just got my '04 FX4 SCrew on the weekend with 65000kms. The only problem (so far) I have, it the mini message board is telling me its 40C outside. It rarely falls below 37. The actual temp outside is 20C so I am assuming the sensor is pooched.
Canadian dealer price is $175. I saw on another thread to go to NAPA but they say its a dealer part and dont have.
My question is, if I didnt repair this, does it interfere with any other settings like fuel mixture etc.....
I am going to push back on the person I bought it from but want to know my options.
I am an electrican and can take some resistance readings if I knew what the specs were.
Anyway......will it damage/change anything if it is reading 10 degrees higher?
Thanks
edit: ps. What is that other sensor located just below the ambient temp sens. It is about 2 inches below mounted on the same bracket? Curious.
Old Sep 5, 2006 | 09:09 PM
xtrm1stang's Avatar
xtrm1stang
the ambient air temp that reads on the dash is only for the dash, the maf sensor calculates intake air temp and that is what is used for engine performance, so you are ok!
I believe the other sensor is an impact sensor for the air bag system
Old Sep 6, 2006 | 07:59 AM
RobInAB's Avatar
RobInAB
Ok...thanks for the reply. Good thing I didnt bang the airbag sensor around too much.
As far as the ambient air goes I will try to get it replaced. I read somewhere the specs are 8k-14k ohms when its 65-80 degress and my readings were no where near that.
Roader
24
Jul 21, 2024 08:27 AM
Roader
Jun 12, 2010 01:34 AM
mjcusee
2004 - 2008 F150
Jul 5, 2008 05:36 PM
jtharvey
24
Apr 1, 2006 08:08 PM
