Manual steering box?
Old Feb 13, 2022 | 10:03 AM
hiball3985's Avatar
hiball3985
Originally Posted by idaho211
It uses a bigger housing, larger roller on sector shaft and 1-2 ton shaft and worm. The roller bearings are larger as well. The end of the sector shaft where the pitman arm attaches is the same as 1/2 and 3/4 ton 2WDs.
Thank you. I'm not sure what you call larger roller bearings on the sector shaft, are these rollers rather then bushings like the smaller boxes on the two wheel trucks?
Old Feb 13, 2022 | 10:17 AM
Mannysouza's Avatar
Mannysouza
So,
The problem was I put the horn button clocked over and didn’t notice it till after the round about. I did communicate with a local steering box company (the owner has been to my place to buy a truck) and he said that none of the obvious was present. So we agreed that I had just clocked the horn button wrong 120*. I pulled the horn button and noticed a notched.
The steering box is different from the 2wd and it is very expensive to rebuild. He said parts would behave to be sourced from another country, and they would also have to forge parts together to make it all work. He stated $600.00 for a rebuild.
he did state that the steering box would not be tight like mine is if it was having problems.
Old Feb 13, 2022 | 10:39 AM
hiball3985's Avatar
hiball3985
Originally Posted by Mannysouza
So,
Well that is good news
Old Feb 13, 2022 | 10:51 AM
idaho211's Avatar
idaho211
Definitely good news. Less cost for sure.
Old Feb 13, 2022 | 11:56 AM
idaho211's Avatar
idaho211
FYI, Dennis Carpenter has a steering rebuild kit for 1/2 ton to 3/4 ton 2WD’s. Includes sector roller, shaft worm, roller bearings, sector bushings, gasket kit. Would need a machine shop to press on the worm on steering shaft and install roller on sector.
Old Feb 14, 2022 | 09:09 AM
Mannysouza's Avatar
Mannysouza
this is a 4wd
Mercmeister
Apr 15, 2010 09:10 PM
micman7
Nov 13, 2007 09:40 AM
Fordnew
1997 - 2003 F150
Apr 16, 2004 08:53 PM
jeffh
Dec 15, 2003 03:22 PM
