Setting up your mirrors to tow
I have a 26-foot travel trailer and 2011 F-250 FX$ 6.2 SC reg bed.
I set my stock mirrors up extended out, where I can see the road and tires of my trailer on the inside edge of the big mirror.
I am wondering if I am too low.
Am I missing too much behind me?
I read where you should be able to see 200 feet back, that seems like a lot.
Just curious, I am a slow driver, never change lanes quickly, I always leave stopping room in front, even if I have to keep dropping back as jerks pull in front of me.
How do you guys set up your mirrors?
I set mine so that in a theoretically-flat road, I see the horizon at about a third of the way down from the top, and so that if I glance at either mirror I only have a sliver of trailer in view. Lean back to see more trailer, lean forward to see more of the lane next door.
Most regions require that you can see 200 feet directly behind the vehicle combination.
Received 6,779 Likes
on
Thanks guys....I think I want to watch the wheels just in case they fall off
I had a episode last year while towing a guy flagged me down, said I had some serious issues with my rear tires. I was going through a very winding road.
I have spread axles.
I did have some inside wear on the tires, rear axle.
I took the trailer in yesterday, and they looked at it and right away saw the tire was not riding right.
They have it now.
I upgraded to a better tire, and even while driving to take it in, another flagged me down.
I think the stouter tires even had more sidewall flex because of the condition of the axle?
We'll see, but thanks for your advice, I will adjust my mirrors accordingly when I get it back.
They have it now.
Same here. I set the upper mirror so I can just see a sliver of the trailer and I angle it up a bit so I can see the upper, rear corner. If I lean forward, I can see the top of the trailer which is good for creeping into camp sites and keeping an eye on branches. The lower, convex mirror I use more for lane changes and things directly next to the truck and trailer. All personal preference and driving type. If I were in the city with a large trailer, I'd lower the mirrors so I could see next to the trailer a little easier.
The front one rides perfect, and the trailer is level, they set it all up when I bought the trailer from them.... so I don't think its my loading too much behind the axle or the togue is too high.
I just want it fixed..... nothing worse than being on the road and someone flags you down, ruins your whole trop, arg.
I can't help but I can empathize. I had a trailer with axle issues and it was constant headaches and heartaches. Never could get it fixed properly and ended up selling it back to the dealership. Closest I ever got to an explanation for my situation was that the axles were actually not able to hold the full amount of their rating, because the manufacturer cheaped out. I have no idea, guess I'll worry about it next time I buy something.
The following users liked this post:
I adjust mine per the example below. The factory Ford tow mirrors are really nice in that they do a great job of eliminating blind spots. The large, top mirror is set to the ("With towing mirror") so that at a glance I can see just down the side of the trailer and any cars to the left or right of the rear of the trailer. The convex mirrors are set pushed out a bit so that I can see a vehicle basically just behind the driver or passenger door. As far as height goes, I just lean forward slightly to see the front tires of the trailer. My main priority is to see the rear corners and potential vehicles in that area.
The following 2 users liked this post by clarkbre:
Here's the other thread:
https://www.ford-trucks.com/forums/1...-question.html
I still used it last year and suffered no ill effects other than the rear tires wore inside more than the others.
I went to a more ply wider tire just to upgrade, as I was going to still pull it on a long multiday day trip of over 1200 miles, but I didn't after all.
I know the spread axles create more flex, perhaps the rear axle is carrying a bit more of the load, I'm not sure, but even given that, it wouldn't really explain it.
I called today, they had it over a week now. The service guy quit or was let go, not sure...
So I am still waiting.
