P0478 dtc code
Old Jan 25, 2022 | 02:08 PM
Brad ORourke's Avatar
Brad ORourke
P0478 dtc code
Hey fellas, for the last few days my ‘06 f250 has been running like it’s dragging a Silverado sideways behind it. Lots of boost, no power, and when I let off the throttle it sounds like blow gun on a air hose with the lever being pushed rapidly. The only code it’s throwing is a P0478. Any known likely issues, and or what I should start looking at?
Thanks guys
Old Jan 25, 2022 | 02:25 PM
bismic's Avatar
bismic
P0478:
Stuck Turbo, bad EBP sensor, slow responding (bad) VGT sensor, stuck VGT valve, or (very low possibility) bad PCM.
This code is set when EP_G is higher than EP_DES by 260 kPa or 37.7 psi for greater than 30 seconds.
Old Jan 25, 2022 | 02:57 PM
Brad ORourke
I was able to find that info, I’m looking for either a possible link to a write up on testing steps, or even just best place for me to start checking
Old Jan 25, 2022 | 03:01 PM
bismic's Avatar
bismic
That all depends on what equipment you have. What are you using for a scan tool? Do you have anything that can command the VGT actuator? The full version of ForScan can do that I believe. Certainly Ford's IDS system can.
Why not start by seeing if the EBP sensor is working?
Compare EBP, MAP, and BARO at KOEO. They should all be close to each other. Just bear in mind that some tuners (like SCT) don't read EBP accurately. ScanGaugeII, Torque Pro, and ForScan can all read EBP accurately.
You can also pull the EBP sensor and see if the tube to the exhaust manifold is plugged, as well as check to see if the sensor itself is plugged up.
Just for good measure, I would also make sure that the MAP sensor nipple on the intake manifold was not plugged up.
Old Jan 25, 2022 | 03:08 PM
Brad ORourke
I do have Forscan, I don’t think it’s the full version though.
Old Jan 25, 2022 | 06:24 PM
Brad ORourke
EBP, MAP, and BARO all around 14 psi KOEO
Old Jan 25, 2022 | 06:41 PM
bismic's Avatar
bismic
Those values look good. I would still clean the EBP tube and MAP port.
The full version of ForScan must be on a Windows laptop, so you probably don't have the ability to drive the VGT solenoid.
I have a link to a turbo guide that might help. otherwise you need to post the commanded VGT duty cycle at various conditions.
Cold idle
Hot idle
High idle
Highway cruise
Light acceleration
Heavy acceleration
Note - there is a diagnosis section in the 6lvgtguide.pdf document attached.
File Type: pdf
Old Jan 25, 2022 | 08:27 PM
Brad ORourke
Ok cool, I’ll check and clean both the the ebp tube and map nipple tomorrow, then I’ll get all the vgt %’s after that. Thanks for your help!
Old Feb 13, 2022 | 10:44 AM
Brad ORourke
Ok so I’ve had to deal with a couple deaths in the family and I haven’t had a chance to mess with the truck until last night. The ebp sensor and tube were both very plugged up. I will check the MAP port/nipple today and then I’ll work on getting those test results for the vgt cycle.
Old Feb 13, 2022 | 11:00 AM
Brad ORourke
Something I didn’t mention since I didn’t know where the MAP sensor was located, I noticed the problem my truck is having, started the day after I replaced the blower motor. I’m wondering if maybe I disconnected the MAP sensor or the tube?
Old Feb 13, 2022 | 11:27 AM
bismic's Avatar
bismic
where is the map sensor on a 6.0 powerstroke
http://www.powerstrokehub.com/servic...20the%20sensor.
Old Feb 13, 2022 | 12:42 PM
Brad ORourke
Yes I found that before my last post, that is why I mentioned that the problem started just after replacing the blower motor.
thelunkster
Mar 14, 2017 07:37 PM
WatsonR
Jun 12, 2015 12:59 PM
farmert
Mar 23, 2015 06:34 PM
Deep South
Oct 1, 2014 01:32 PM
pmasley
Apr 6, 2006 10:13 PM
