Trailer brake issue
Old Jan 21, 2022 | 05:48 PM
_Godzilla_'s Avatar
_Godzilla_
Trailer brake issue
Searched and cant really find much on the topic but its a serious problem. Truck is a 22 F450 KR about 6K miles on it. I tow almost everyday usually around 20K(construction equipment), I hook up a trailer test the brakes everything works good no issues. About 40-60 minutes into the drive the brakes will just decide to stop working. No error message no trailer disconnected they just stop working, even when you manually use the brake controller. It is defiantly the truck as it happens no matter which trailer I use. I have tried switching the plug when it happens, tried dielectric grease, doesnt change anything. All the lights will still work properly just no brakes. If you shut the truck off for about 15-20mins they will usually come back and again work for 40minutes or so. Truck has been to the dealer and is going back again monday, so far they have done some software update but dont have any real idea what is going on. Anyone else ran into such issues?
Old Jan 21, 2022 | 06:13 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
I’d have them replace the module under the dash for the controller. Best place to throw parts at first.
Old Jan 21, 2022 | 06:15 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Never heard that one before, but many times these situations can be traced back to a poor grounding issue.
Can't say for sure that is your truck's issue, but maybe.
Old Jan 21, 2022 | 08:39 PM
powerboatr's Avatar
powerboatr
Hookup forsca n and see what's being set .
I had a ton of issue a recently. Truck kept disconnecting trailer ...etc. ran forscan and it was breakaway battery....you would think dash might say that.. But nope just a fault
Old Jan 22, 2022 | 07:46 AM
B-ManFX4's Avatar
B-ManFX4
+1 on the dead breakaway battery. Easy test - bypass it, make sure the brakes function and leave it that way for a day's drive and see if the problem re-occurs. Mine was dead and I got all kinds of screwy reactions with the truck electronics. I bypassed it and it worked perfect every time.
Old Jan 22, 2022 | 07:50 AM
Baja Fog's Avatar
Baja Fog
Have you checked the trailer end if things? Broken / disconnected wires betw÷n the connection and the hubs?
Old Jan 22, 2022 | 07:56 AM
acadianbob's Avatar
acadianbob
Or maybe tow a different trailer to eliminate the possibility described above?
Old Jan 22, 2022 | 04:09 PM
_Godzilla_'s Avatar
_Godzilla_
Cant be the breakaway battery, i have tried three different trailers and it happens on all them(one of which is brand new), same scenario. The issue is without a doubt the truck, I will try forscan.
Old Jan 22, 2022 | 05:05 PM
husqvarna's Avatar
husqvarna
https://www.ford-trucks.com/forums/1...ake-issue.html
same thing happened to me. But once I had my fifth wheel plugged in to my truck for like 20 minutes, it was perfectly fine. So I figured maybe the battery wasn’t charged enough? Not sure. But it’s working fine now 🤷🏻‍♂️🤷🏻‍♂️
Old Jan 22, 2022 | 08:34 PM
Joe T's Avatar
Joe T
Zip tie the trailer 7 way on the factory side tight. Make sure the factory connection is good.
Had this happen on a 2013 but it was obviously a bad connection.
Edit: actually you cant do that on a new one but you get the idea…. Maybe use a different method.
GMoney1121
Jan 13, 2022 02:36 PM
Eric Ahl
All Things Towing
25
May 28, 2017 07:06 PM
brkncly
6.4L Power Stroke Diesel
Oct 25, 2012 01:18 PM
jsmithis101
2004 - 2008 F150
May 7, 2012 08:42 PM
Old Fudd
All Things Towing
23
Feb 25, 2012 07:09 PM
