Lone Star- 4wd Conversion
Old Apr 5, 2022 | 12:24 PM
  #76
Ford Firefighter's Avatar
Ford Firefighter
Originally Posted by fordman67
awesome work!!
Adj the box yourself!! I do on every one I have ever had
Thanks!
Adjust.. like the 5/8 jam nut and the Allen key adjust? If so I have already done that and it’s already a tad too tight and still has movement.
Old Apr 5, 2022 | 01:40 PM
  #77
Edgethis's Avatar
Edgethis
Originally Posted by Ford Firefighter
@Edgethis What kind of set up do you have? It’s always fun to hear about your truck lol
The steering setup on my truck is stock-ish looking. Since I have SD knuckles, I have the beefy SD tie rods and then it all bolts up to the stock drag link. I of course had to make custom brackets to rub my steering stabilizers. Looking at your sweet Bilsteins makes me want to swap the shocks put on mine now.
Old Apr 5, 2022 | 01:49 PM
  #78
Ford Firefighter
That’s sweet man!
Do you like the bearing units better than the whole spindle nuts deal?
PMF has a nice dual stabilizer that I was eyeing, SKY’s said it only works with a high steer set up.
Old Apr 5, 2022 | 01:52 PM
  #79
Ford Firefighter
Video!
Old Apr 5, 2022 | 07:55 PM
  #80
Edgethis's Avatar
Edgethis
That is a nice video. Dual Bilsteins and all!
You should get the SD diff cover. It was like $30 from rockauto when i built the rear axle for my truck.
I do like the sealed front bearings. Not as messy and it's a pretty easy install once you know what to do.
Old Apr 5, 2022 | 09:01 PM
  #81
Hit Man X's Avatar
Hit Man X
Only John Holmes guys rock the Maghytec like me.
Old Apr 5, 2022 | 09:53 PM
  #82
Ford Firefighter
Sweet I’ll check it out! Thanks!
Old Apr 6, 2022 | 04:45 AM
  #83
Edgethis's Avatar
Edgethis
It's super nice and then I think it was like $5 for some nice stainless button head bolts to hold it on.
The Magtechs are nice like Eric has, but I'm cheap.
Old Apr 6, 2022 | 06:38 AM
  #84
Ford Firefighter
Wow that is sweet looking! Yeah idk about poping for a mag cover, I like the look of that one!
Where did you steal yours from Eric?
Old Apr 6, 2022 | 07:41 AM
  #85
Edgethis's Avatar
Edgethis
Yeah I spent all my money on the trutrac diff inside and Timken bearings.
Old Apr 6, 2022 | 07:47 AM
  #86
Ford Firefighter
Has it worked well for you?
I just hate the idea of having to pull it all apart to replace clutches after awhile! I’m just lazy I want to do the work and be DONE with it! Lol
Old Apr 6, 2022 | 07:48 AM
  #87
Ford Firefighter
I mean are they really maintenance free?
Old Apr 6, 2022 | 08:26 AM
  #88
Ford Firefighter
Panhard (Track Bar)
I have come to realize I made a hurried mistake when mounting the Track-bar bracket!
I bolted it up into place right where the axle and truck sat without checking to see if it was even close to being square with each other (truck & axle)
So when it came time to adjust it into place after I had driven it a few miles I realized that it was at least an inch and a half out of wack! And so there wasn’t enough threads to get it just perfect I’d say I’m about 3/8 of in inch off which isn’t great but it ain’t gonna kill me!
So the correct way would be to set your pair of plum bobs over the hood and check it before bolting the bracket to the cross member, that way you will have room to make subtle adjustments.
This would definitely need to be done before the alignment because they use the rear tires as a guide.
I think I am going to unbolt my bracket and weld it to the crosmember in the correct place before I get my alignment finished, after the red head steering box!
Old Apr 6, 2022 | 12:13 PM
  #89
Edgethis's Avatar
Edgethis
Absolutely
There's no clutches on the tru tracs. They use helical gears that screw and unscrew to lock both wheels together when they spin at different speeds. Best diff out there in my opinion, for a general use vehicle.
Old Apr 6, 2022 | 04:27 PM
  #90
Hit Man X's Avatar
Hit Man X
Thumbs up
Who told you I am THAT scummy? Swindled someone to freight it for a C-note.
I beat my Truetrac in the 6.4 like it owed me money to a 12.9@105 run with stock snails on a modest tune. CCLB F350 4x4 Lariat, big weight. 4.9 receives first, then the dually...provided the dually engine not kaput. Injectors going in today.
