Down the rabbit hole
https://www.ford-trucks.com/forums/1...l#post19084158
I'll second replacing the HPOP hoses. Yours look OEM and they have a rep for failing with age. And when one pops you're on the side of the road lickety split.
There is a neato updated design from Riff Raff.
@Kwikkordead did you actually luck out and break down in Ely? There's hundreds of beautiful but empty square miles around Ely.
Both my wife and I were born, raised, spent our whole lives in the Seattle, WA. area. Ran an auto repair business for 38 years until I retired in June, 2020. Moved to an area an hour's drive south of Tucson right after that. But before we did retire we made many trips between WA and AZ. The shortest route between the two states is Seattle, Ellensburg, Yakima, then cross the Columbia at Hermiston, OR area and follow 84 to Twin Falls, ID. We actually get off 84 at Bliss, ID and cut over from there to catch 93 south all the way to Las Vegas. From there, we go and get off of 40 just past Kingman and follow the highway through Wickenburg, then Phoenix, then Tucson, the follow 19 to home. So yes, we've been through there many times and I love the remoteness of it all. I've made the drive now so many times, I don't need my Garmin any more for that particular trip, LOL.
There is a DoD test range just south of Ely headed toward Tonopah on Hwy 6 (just north of 375) that we used to fly to twice a year and "test" things. That spot/area was selected due to the proximity to other test ranges in the area and it being the "least populated portion of the United States in the lower 48". It is just before you hit the hot springs pool on the right if you are headed south.
Coincidentally, my wife and I had been by the range a couple of times on our way to or from the SW and ID before. I still need to take her to see Devils Chair (hill that looks like a chair), the huge crater by the dry lake and the atomic test site out there.
_______________
As for the high pressure power steering line. I bought a new Motorcraft from Clay at Riffraff a couple of years ago when I was in the engine bay knocking out some other maintenance items. I made sure to use some reinforced hose to guard the power steering line where it crosses near the shock tower too. I also put a rubber boot over the sharp fitting so as to not damage the CAC tube on the driver side. If/when I need to replace the Motorcraft line, I will go with the custom built design mentioned and linked above. This came out after I had replaced my OEM line with another Motorcraft.
only downfall for the entire trip was I had no signal for 3hrs on the stretch south of the Donner
on a side note I purchased a topside creeper last year when I did glow plugs…my knees absolutely love it, if you are still debating its a great purchase and almost a must have for working on pickups’ and SUVs’.
I also noticed some difference in the plenums vs. the instructions on riffraff’s website. These ones (my truck is an e99) do NOT require the bolt by the HPOP to be cut, and are slotted like the OEM design where as the instructions say that the bolt is omitted. I also noticed the studs that hold the bracket for the starter relay do not get re-used as the instructions state. My studs were not long enough the fit with the spacers provided; instead there were two longer allen head bolts in the kit from Riffraff that were used with the spacer against the plenum, the bracket for the relay, and then the bolt went through the whole thing. No complaints as the set up is great, just a few difference between the later model design vs the e99 set up.
Now for the pictures
Old vs new plenums. Really impressed with the fit and design improvements of these vs the OEM design
After cleaning out the rats nest. After snapping this photo I degreased and scrubbed the top of the motor.
New plenums installed (note that the batteries are disconnected to avoid any issues with the lose wire by the relay)
Cleaned the turbo pedestal best I could with a wire brush and got that re-installed along with the O-rings from the turbo re-install kit.
You might want to put a glove or something over the plenum holes to prevent anything from dropping in.
Edit: just noticed the last photo. Looks like you already have it taken care of with towels.
Scared me seeing the GPR work with the open holes.
Shes all back together now, and running. No oil or fuel leaks, making more boost as well.
So far with this repair blitz:
-All intercooler boots and clamps
-Plenum boots and clamps
-Billet aluminum plenums
-HPOP lines
-Rebuild IPR
-Reseal fuel bowl (wasnt leaking but figured it was out on the bench may as well)
-Replace the driver side A-pillar gauge mounts with cleaner design supplied by Riffraff (previous owners gauges work great but the mount was cheap looking)
Whats left for this repair blitz:
-Passenger side window regulator
-Repaint the dash bezel with the right shade of dark brown (when I rebuilt the radio previously the color I picked didnt match the way I wanted it to)
-Oil Pan Gasket
-Oil Change
-Transmission flush (drain and fill)
-Coolant flush (Drain and fill)
-Check other fluids and change as necessary
-Clean and detail the interior and exterior
Decided to save the power steering line for the next time, at some point I needed to quit spending $$ and swapping parts that are not broken yet. I did make some temporary fixes with heater hose wrapped around the rub points and electrical tape to protect some exposed wire harness.
Now for the pictures:
Resealed the fuel bowl with new O-rings.
Turbo back in, that clamp to the up-pipe collector sucks…
Intake “spider” back in.
New plenum boots.
All back together and driving.
Ill update in a few days when I start the next phase of this saga…
