CDR
Old Apr 20, 2010 | 09:39 AM
mabc926's Avatar
mabc926
CDR
How do you hook up the CRD to an engine with a turbo?.....I don't know if you still use the hole in the back of the intake or not I would think that would cut down on my PSI.....I know Dave S has a pic where it's on the valve cover but I don't know how to hook it up....the way it was hooked up when I got it just didn't look right that's why I'm asking.
I'll upload some pics soon to show you all what I'm talking about and see if you can help me
Old Apr 20, 2010 | 10:17 AM
mabc926's Avatar
mabc926
Alright got some pictures
Here's how the CRD as hooked up it's turned backwards to the hole in the back of the intake was wide open letting out all the PSI that's why I plugged it.
And here's how it all fits together......I have no clue where the tube runs too it was already off the truck when I got it.
Old Apr 20, 2010 | 10:41 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
The CDR is relocated on turbo motors, where depends on the kit.
I believe (I don't have one) ATS does it between the rocker cover and the air intake before the turbo.
I believe (I don't have one) Banks does it between the IP Gear cover and the air intake before the turbo.
Someone will squash me (deservedly) if I'm wrong. (but I won't forget then)
[edit]
THIEF! Those are my colors!
Purdy color!
Never seen one installed like that. But I haven't seen everything.
[/edit]
-Enjoy
fh : )_~
Old Apr 20, 2010 | 01:50 PM
wreckinball's Avatar
wreckinball
Wow that is the random photo of the day! amazing how some problems are cured, thats downright interesting.
Old Apr 20, 2010 | 01:53 PM
mabc926's Avatar
mabc926
Hmm...so I guess sense it's a homemade turbo kit I'm going to have to make my own way to hook up the CDR.....crap, now I'm going to have to get my brain working again and think of something
Well I'd like to keep it going in the valley pan so I don't have to cut holes in my FRESHLY pained valve covers.....so I guess I'll just keep it where it is and run a tube from it to the air intake before the turbo (have to make an air intake too)
I'm thinking a nice chrome braided metal tube with a chrome intake might look nice with the green and black.
Thanks for your help, and if anyone has any other ideas of how I could mount/move the CDR please let me know.
Old Apr 20, 2010 | 02:01 PM
wreckinball
As long as the CDR is able to drain back to the valley pan, you can move it to the "custom intake" you are building and run a similar drain tube to the valley pan. So mounting it to the intake you build with a drain tube and whatever else you need might just work. I would get some ideas on paper or metal for the intake and go from there.
Old Apr 20, 2010 | 03:23 PM
Sycostang67's Avatar
Sycostang67
Never seen a CDR done like that. As long as you run the tube to the intake(pre-turbo/post filter), I dont see why it wouldn't work as it should.
Old Apr 20, 2010 | 10:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Where does the turbo lube oil return to the engine?
Old Apr 21, 2010 | 08:43 AM
mabc926's Avatar
mabc926
I'm not for sure where it goes, haven't had enough time with the truck to look at it all, I do know the tube that hooks to the turbo runs under the engine if that tells you anything.
Old Apr 21, 2010 | 01:01 PM
Festus Hagen
Methanoholic
There are two oil hookups on a turbo ... Supply and Return.
Thats likely the supply.
-Enjoy
fh : )_~
Old Apr 21, 2010 | 08:16 PM
Marianna2003's Avatar
Marianna2003
That manifold is to pretty to bolt that ugly CDR & Hose to it.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
