Suggested work
Old Jan 11, 2022 | 05:56 AM
Dcal's Avatar
Dcal
Suggested work
I’m replacing the tranny in my ‘03 7.3 and wondering if there is another job I should take advantage of while it’s out?
it’s an automatic transmission, 4R100 and has just over 250K miles on the truck.
Old Jan 11, 2022 | 06:16 AM
Hyakkimaru's Avatar
Hyakkimaru
Definitely reroute your engine valley drain. (mainly stick) The factory valley drain goes right onto the clutch. So if you have a fuel leak you are dumping diesel onto the clutch. Same with oil of course! Would be a good time to look at U-joints, and check all your wiring going to the transmission making sure nothing is rubbing. I had my reverse wire land on my drive shaft and rub through
With the transmission out it's also a lot easier to get at up-pipes and whatnot. So if you were wanting to make the system better you could put some bellowed up pipes on!
I see now that you said it was an auto. The first bit I wrote dosen't apply to the auto trans😅
Old Jan 11, 2022 | 06:41 AM
SkySkiJason's Avatar
SkySkiJason
The up-pipes are easier to do with transmission out, but it’s still another project. The biggest advantage is being able to remove the bolts from exhaust manifolds to up-pipes. If not able to tackle an additional project, consider just replacing those bolts.
The procedure with transmission removed is still basically the same. The advantage to no transmission is the ability to have a helper line up the collector to turbo while installing the clamp.
https://www.ford-trucks.com/forums/1...lete-pics.html
Old Jan 11, 2022 | 07:27 AM
Dan V's Avatar
Dan V
Have a good look at the oil galley plug on the back of each head.
Old Jan 11, 2022 | 08:33 AM
Wes444's Avatar
Wes444
Add some under cab sound deadening to transmission tunnel
Old Jan 11, 2022 | 09:32 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Drive shaft U-joints, slip joint and carrier bearing inspection.
Old Jan 11, 2022 | 09:33 AM
Rot Box 2's Avatar
Rot Box 2
6.0 cooler if you don’t already have one. Well worth the upgrade.
Old Jan 11, 2022 | 10:42 AM
SkySkiJason
100% this!!!!!
I automatically upgrade cooler with transmission rebuild. It’s better than hoping the old cooler is clean AND it’s better at COOLING.
Old Jan 11, 2022 | 02:11 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The OP has a 2003, which came from the factory with the large under cab sound deadening panel in the lower transmission tunnel, that spans the width of the cab almost from frame rail to frame rail above the transmission.
The 1999-2001 trucks did not come with this foil covered fiberous panel under the cab, but 2002 and 2003 models did. Even the lowly XL models. So that is one less thing to do on the OP's list.
Old Jan 11, 2022 | 04:19 PM
HKusp's Avatar
HKusp
Mishimoto tranny cooler is a nice upgrade and lifetime warrantee'd for about $100 more than the Dorman 6.0 cooler. I agree with the up pipes while the tranny is out of the truck as well.
Old Jan 11, 2022 | 10:32 PM
Dcal's Avatar
Dcal
I already purchased the mishimoto tranny cooler but yes good advice… I know myself and once that tranny goes back in the last thing I want to do is take it out again to do a repair I should’ve done while it was out!
cowmilker08
Mar 17, 2009 09:26 AM
Mountain Synergy
Sep 5, 2008 10:03 PM
jscarb2
Oct 15, 2005 02:52 PM
michaelmueller
Jul 26, 2004 09:25 PM
state
Aug 19, 2003 12:51 PM
