Hard start hot
Old Jan 10, 2022 | 11:43 PM
JD Man 58's Avatar
JD Man 58
4wd Low
Hard start hot
I have a 2006 F-350 6.0 and had a couple injectors replaced, also had HPOP replaced all about 12,000 miles ago truck has been doing pretty good but I have recently started having some issues. It’s getting hard to start after it’s warmed up. I have to hold the throttle all the way down and crank it for 10 - 15 seconds before it will start. Also it smokes all the time when sitting idling. It didn’t use to do that. Also when it shifts down from 5th to 4th it blows a big puff of black smoke. And it has developed a bad oil leak about a half gallon a day. I keep it full though. I work all the time and just haven’t had time check it out. Any ideas or help much appreciated in advance.
Old Jan 11, 2022 | 08:53 AM
Brotherbillstruck's Avatar
Brotherbillstruck
Here is a start. You need to find the oil leak. The Tech folder at the top has lots of good info.
https://www.ford-trucks.com/forums/8...att66f100.html
Old Jan 11, 2022 | 08:59 AM
xcrsp440's Avatar
xcrsp440
Are you loosing oil onto the ground or is it just disappearing from the dipstick?
Old Jan 11, 2022 | 09:06 AM
bismic's Avatar
bismic
Just a little more back ground:
https://www.ford-trucks.com/forums/1...-no-start.html
Old Jan 12, 2022 | 06:03 AM
JD Man 58's Avatar
JD Man 58
4wd Low
Well the oil is going on the ground. Its pooled up in the valley I know some of it is coming from passenger side valve cover but not that much. I think the guy put my injectors in didn’t do it right also. That may be why it won’t start hot sometimes. I’ve got an edge programmer on it. Just in tow mode level 2 out I got icp pressure set up on the gauge and it usually reads between 500 and 600 while it’s turning over and won’t crank.
doninreno
Sep 23, 2018 09:30 AM
Hoffcos
Jun 17, 2017 11:23 PM
Insley95
16
Jun 30, 2014 07:18 AM
Trucky2
Sep 23, 2010 06:33 PM
jlsdcen2
2004 - 2008 F150
Oct 20, 2009 12:02 AM
