Hard/No start Hot
Old Sep 14, 2010 | 08:37 AM
Trucky2's Avatar
Trucky2
Hard/No start Hot
Truck starts and runs perfect almost always. 2 times now when shut off for just a few minutes it will just crank and refuse to start. So far, letting it sit about 15-20 minutes and it fires right up. Anyone near Asheville with an AE so I don't start replacing unneeded thingies?
Old Sep 14, 2010 | 10:25 AM
DieselCamper01's Avatar
DieselCamper01
Not sure if this applies to your situation or not but I occasionally have this happen also. I have not pursued yet why this happens. What has worked for me up to this point though is just shutting the ignition off and restarting. Fires up every time when I do that.
Old Sep 14, 2010 | 10:41 AM
Trucky2's Avatar
Trucky2
I've tried that... Took the keys out and walked back in the store for a few minutes. Tried again a few times and only got a very healthy crank. It was dark so I didn't really notice any smoke. After about 20 minutes, normal crank time and start.
Old Sep 21, 2010 | 01:54 PM
ggirten's Avatar
ggirten
Mine is doing the same thing. When it is cold it cranks fine, but when it's hot after use it either takes a minute or refuses to start. I have replaced the IPR and icp without any luck. My IPR duty cycle is a lot higher than it should be. I have been told leaking O'rings on the injectors could cause this issue, but I don't undertand why letting it cool off will let it start.
Old Sep 21, 2010 | 06:15 PM
F350-6's Avatar
F350-6
No start when hot can often be an IPR issue. While you wait on someone with an AE to chime in, be sure to make sure the tin nut has not fallen off the back of the IPR.
Because the colder the oil gets, the thicker it becomes. Thicker oil will leak past an o-ring slower which means you can build more pressure against the leaking o-ring.
I don't know if your issue is indeed o-rings, but that is the reason cold oil will help the truck start faster if the o-rings are worn.
Old Sep 21, 2010 | 10:03 PM
KH85's Avatar
KH85
Perfect timing! Mine does the exact same thing. Though I have yet to have a no start. Fires perfect when cold but when hot it will turn over slower and take a bit longer to fire.
So I was wondering if this could possibly be a starter goin bad? Should I have it tested and does this sound like the same IPR/leaky o-ring issue?
Sorry for the kind of hyjack. Hopefully our problems are the same and we get em taken car of.
Old Sep 22, 2010 | 01:27 AM
cooljman1's Avatar
cooljman1
i too am in the same boat, so far it has awalys started but it sure cranks alot longer before it fires up.
Old Sep 22, 2010 | 01:58 AM
Visseroth's Avatar
Visseroth
Could be fuel pump too. If the pump gets hot then it may not like to work either. Next time it doesn't want to start turn the key off, then back on and put your head under the truck and see if you can hear the pump working, if not then there ya go, if so then yea, leaking oil sounds like it's the problem to me.
Old Sep 22, 2010 | 02:19 PM
KH85's Avatar
KH85
Ok I'll try this. But like stated it has not not started yet just slow. And I just did my intank mods and ran the pump alot to cycle fuel into the filters and what not and it never gave me any trouble.
So would say it probably is leaky o-rings or could this possibly be the starter getttin hot too and not wanting to fire properly?
And is there any way to check for bad o-rings aside from pulling the injectors?
Old Sep 23, 2010 | 01:14 PM
Trucky2's Avatar
Trucky2
Happened again, this time to my daughter as she ran in to get a gatorade, so the truck was off maybe 4 or 5 minutes. I told her to sit it out and call me if it won't fire after about 15 minutes... Short of going to the dealer do any of the auto parts carry a reader that can pull codes?
Old Sep 23, 2010 | 05:38 PM
KH85's Avatar
KH85
Not too sure but I dont believe auto parts stores usually have scanners that will work on our trucks.
But ill give a little bump to see if someone else will chime in with a better answer.
Old Sep 23, 2010 | 06:33 PM
Action4478's Avatar
Action4478
You will need live data from a scanner . ICP pressure ,IPR DC % , or hook a manual gauge to it ..
IPR O rings are a cheap test
kayakfl1982
North Carolina Chapter
Apr 17, 2015 09:57 PM
Monty Simmons
Feb 9, 2014 08:15 PM
tacson
Jul 3, 2013 06:19 AM
tcbaldmtn
Jun 26, 2006 06:54 PM
turboale
May 16, 2006 09:27 AM
