Reading the trans dipstick
Old Jan 1, 2022 | 05:57 PM
zedsdead's Avatar
zedsdead
88' 351W C6
After finishing my rear main, I refilled the trans with about as much fluid as I took out according to the oil catcher. About 5 quarts.
However, when I look at the dipstick at hot idle the dipstick is impossible to read... one side says way way too much, the other side says Im a little over.
I'm an over thinker, I know most people would move on with their day. But since its the trans I don't want to mess it up.
Thanks for your advice
Old Jan 1, 2022 | 06:50 PM
timbersteel's Avatar
timbersteel
Was the trans fluid showing correctly in the hash marks before draining?
Have you cycled the gear selector through all gears once and back to Park, and then checked it?
Old Jan 1, 2022 | 10:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The lowest dry spot on the dipstick shows the actual level. The stick drags on the tube and spreads the fluid higher, usually just on one side. Ignore that side and read the other side.
Old Jan 4, 2022 | 10:09 AM
zedsdead's Avatar
zedsdead
Thanks Mark. I took it on a long test drive, got it nice and hot. Then, I cycled the gears.
According to the lowest side of the dipstick, the level is good.
JWA
Jan 17, 2013 07:41 AM
nickwestover17
Oct 16, 2010 06:07 AM
Headviking
Aug 16, 2010 07:43 PM
$Simpleman76
6.7L Power Stroke Diesel
Apr 24, 2010 10:30 AM
superduty lee
Modular V10 (6.8l)
Nov 14, 2006 01:47 PM
