Trans Fill?
Old Jan 17, 2013 | 06:23 AM
JWA's Avatar
JWA
Trans Fill?
Anyone have a better method of pouring 13 quarts in the transmission? The dinky dipstick tube has traditionally been my way, surely there's a better way?
TIA
Old Jan 17, 2013 | 07:29 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The only other way is to take the trans out of the truck, remove the converter and pump, and pour it in there. There are no other openings in the transmission to add the fluid.
Don't pour all 13 quarts in at once. Add 8 quarts then run the engine for one minute. Not two minutes. Shut it off and add four more, then start the engine and warm up the trans. Use the last quart to set the correct level.
Old Jan 17, 2013 | 07:41 AM
JWA's Avatar
JWA
Not better source for trans advice than the esteemed Mr Mark Kovalsky!
Thanks as always Mark!
nickwestover17
Oct 16, 2010 06:07 AM
Headviking
Aug 16, 2010 07:43 PM
$Simpleman76
6.7L Power Stroke Diesel
Apr 24, 2010 10:30 AM
60RatRod
Mar 7, 2009 05:14 PM
ford390gashog
Apr 10, 2004 09:00 PM
