Battery cables
A cool trick I like doing with the 2/0 cable and 10ga wire coming off the starter is to run them both through about a 4ft piece of rubber hose (3/4” ID). That way from the starter all the way up to the battery they are heavily protected. Lots of things to rub on when passing between the oil pan, crossmember(s) and frame.
Measure 5 times and cut once. Three times for the route and length of the cable and twice for the cable itself before cutting it.
Plan for an additional ground from the alternator to the driver side ground terminal. If you ever plan to upgrade your alternator to a higher amperage output, now would be the time to fuse the B+ post and install a secondary main positive cable from that fuse block to the passenger side battery positive terminal.
You see, the best part about going custom cables is you can build exactly what you want, but the possibilities can be overwhelming at times. Proper planning and future proofing is a key component to being successful.
There are many write-up and many more images of how FTE'rs accomplished some of these tasks for you to dissect and learn from. Use this resource so you can be successful the first time around. The link below is how I accomplished bolstering the main cables which is loosely based on the method Y2KW57 took.
Link: https://www.ford-trucks.com/forums/1...light=Positive
Start making a list of what you will need in the way if cabling, lugs, loom, hose, ties, terminals, etc. Take your time and be methodical about it.
Have fun with it, this will be a big project that will liven up the starting, charging and electrical output systems of the truck.
"now would be the time to fuse the B+ post and install a secondary main positive cable from that fuse block to the passenger side battery positive terminal."
Sous, I ran a positive cable from my new alternator ( purchased from quick start, alternatorparts.com )
I installed extra black ground cable to drivers battery ground post, and then installed a red positive over near the starter solenoid, but I never hooked it up, because a mechanic told me it could start a fire. What is the B post you speak of?
Where and what size fuse type would I install?
and lastly, is there a best spot to attach the secondary positive cable to?
Thank you very much!!
P.S. I copied the quote and then wrote my response before I saw the link Sous posted, but I still wouldn't mind having my questions answered here.
- Where did the "red positive" cable start at that is now sitting over by the starter solenoid, but not hooked up?
- Your mechanic is partially right, a poorly installed or terminated positive cable could in fact start a fire. But, if it is properly ran, terminated and fused, the possibility of starting a fire are next to zero. This is how OEM does it on every make and model of vehicle produced.
The B+ post is the positive post/terminal/connection on the back of the alternator that supplies charging voltage to the batteries, which power all of your 12v systems and accessories. You can see the B+ post in the image below from my install. It will look different than yours because I have modified it with an protective post extension and a 2 way fuse block.
As for fuse type and size, you have to remember that the fuse is there to protect the wire from burning up due to a short or an amperage draw that exceeds its rating. Please see the link below for the parts (including fuses and a block) that I selected based on my research of FTE'rs that traveled this journey before me like Y2KW57 and many others.
Link: https://www.ford-trucks.com/forums/1...l#post17789538
The best location to attach the secondary positive cable that is now run to the passenger side battery is on the passenger side battery positive post. Keep in mind that good terminals/clamps should be utilized as an electrical circuit is only as good as its weakest link. With that said and in mind, it is a good idea to match the gauge of the positive wire going to the gauge of the driver side battery. You want to match the wire to the largest diameter that is required though, not the smallest. So, you don't want to select the same gauge wire for the passenger side battery that is already there for the driver side battery. The distance to each of the batteries if very different based on your path of travel for the wires. You will see my selected path of travel and gauge choices in the link.
Since installing the bolstered wire, fuses, alternator, batteries, etc... The system has been flawless and I have complete confidence in it.
Again, if I have failed to answer your questions or address your concerns, I would be happy to take a second swing at them if need be.
Very nice write-up with a lot of good information. Thank you sir! I will work on getting a bunch of cable together along with crimps and whatnot when I get caught up with all my other projects. On a side note, how many cranking amps do the batteries you guys use have? I replaced both batteries last year with 750 CCA batteries from O'Reilly's and I paid $160 a piece for them. I will also do as you recommend and put a 3/4 inch hose over the cables that run down towards the starter.
I will do a ton of research between now and then.
Now that being said, it can be eliminated, but not just by running a new charge cable to the battery(s). That wire feeds your glow plug and AIH relays. So if you redo the supply wiring for your glow plugs, you can then eliminate that cable from the alternator. I also want to do some battery cable/terminal work on my pickup. The factory battery terminals are quite sad!
I purchased a new red Napa battery cable, and attached it to the hot terminal on the back of my new 140 amp alternator purchased from - quick start High Output Alternators alternatorparts.com
I had to modify the post insulation to make it fit along with the original one going to Driver's side battery. I then ran it along windshield border of firewall.
Since I did not have fuses, isolators etc., I wrapped it in paper towel and tape. A few days later a mechanic warned me of the impending doom scenario, so I have left it hanging for a year.
I purchased a new black Napa battery cable, and attached it from the additional grounding bolt on the back of the alternator to the negative post terminal on the Driver's side battery.
However, I do not like how high it sits under the hood, as I attached it to original terminal..
So again, Today I have l looked at the above link, https://www.ford-trucks.com/forums/1...energized.html
and will proceed accordingly.
As always, a big thank you to all those that contribute to this site!
Last question, I know you went to the local wire shop to have your ends crimped on but, what material do you prefer your crimped ends to be made out of? Copper? To me it seems like the copper color would look weird. Maybe I'm a little too picky.
