Battery cables
Old Jan 18, 2022 | 11:42 PM
  #76
dannyual767's Avatar
dannyual767
Earlier today I was looking through my Waytek Wire paper catalog and found that they carry the striped split loom.
.625", Black w/ Gray Stripe, 100'
As of 1/18/2022, it's $26.84. This is the good stuff that can take temperatures up to 125C/257F. Now for the bad news. The last time that I purchased from Waytek, they penalized me for my small order. I think that they want orders of $40 or more. In addition, their shipping charges have really skyrocketed. I think their minimum shipping charge is now over $20. It was $17.50 the last time I ordered last summer. That's painful when your order with them is $35 and your handful of plastic, Metri-Pack electrical connectors weigh all of 6 oz! I haven't ordered from them since.
Most of their stuff is priced low but they want you to buy in quantity for most items. If you need a lot of electrical supplies, even with their high shipping, you can still come out ahead.
Old Jan 19, 2022 | 02:01 AM
  #77
Hyakkimaru's Avatar
Hyakkimaru
That is pretty cheap. 26.84$ for a 100 ft roll. That's amazingly cheap. I like that idea better!
Old Jan 19, 2022 | 07:33 AM
  #78
FordTruckNoob's Avatar
FordTruckNoob
Thank goodness I have a Waytek warehouse close to me. I can walk into Will Call and pick my order up.
Old Jan 19, 2022 | 07:41 AM
  #79
Hyakkimaru's Avatar
Hyakkimaru
Isn't that just handy
Old Jan 19, 2022 | 08:59 AM
  #80
dannyual767
I'm jealous! Waytek really has some good prices and they carry a tremendous selection of high quality electrical parts; many that are made in the USA.
Old Jan 19, 2022 | 09:03 AM
  #81
dannyual767
It's a very good price for that striped loom. It won't go bad sitting in your garage and you'll have it for your next project or your buddy can buy some of it off of you when he's working on his project.
You can probably find some other electrical things that you need to add to your order to help "justify" what Waytek is going to charge you for S&H.
Old Jan 19, 2022 | 09:04 AM
  #82
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Good to know. Way te ko.
Old Jan 19, 2022 | 09:19 AM
  #83
FordTruckNoob
Old Jan 19, 2022 | 10:03 AM
  #84
Hyakkimaru's Avatar
Hyakkimaru
I can sure enough find some other electrical things I "need". I love electrical stuff!
Old Jan 19, 2022 | 10:04 AM
  #85
Hyakkimaru's Avatar
Hyakkimaru
Hahahaha
Old Jan 19, 2022 | 10:08 AM
  #86
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Not that it is any matter to you, but I buy my wire loom in 50' or 100' bundles and store the excess in my garage attic space in a box. There are always projects that wire loom comes in handy. From wiring up a home entertainment system to installing accessories in a vehicle to adding a circuit in the 5th wheel.
Our most recent use of 1" wire loom was to run from a flat screen TV mounted on the wall to a sound bar 6" above the TV. I painted the wire loom to match the brick mortar color and ran it from the TV to the sound bar. You cannot even see it is there unless you are looking for it.
Old Jan 19, 2022 | 10:17 AM
  #87
Hyakkimaru's Avatar
Hyakkimaru
Originally Posted by Sous
Not that it is any matter to you, (it might ben) but I buy my wire loom in 50' or 100' bundles and store the excess in my garage attic space in a box. There are always projects that wire loom comes in handy. From wiring up a home entertainment system to installing accessories in a vehicle to adding a circuit in the 5th wheel.
Oh I'm definitely buying 100' of the 5/8s and 100' of something a bit smaller. Maybe 3/8s for smaller jobs on stuff. And I will definitely find other stuff to but as well. I will use it indoor and outdoor I guarantee it! I did a little tv gaming setup in the past and I ran the wires very cleanly but I didn't have loom so I need to redo it!
I'm gonna order my tape for the loom from them as well!
Old Jan 19, 2022 | 01:02 PM
  #88
FordTruckNoob
By the same token, thick insulation on wires is not necessarily good insulation. Look up TXL (and similar) wire.
Old Jan 19, 2022 | 01:29 PM
  #89
dannyual767
I agree and I use TXL wire. I've been buying it in 100' spools from ProwireUSA I'm about to place another order for two 100' spools of 14AWG TXL wire for $21 each.
Here is another link that quickly describes the difference between TXL, SXL and GXL wire as well as PVC covered, "primary" wire: https://nassaunationalcable.com/blog...-right-for-you
The XL wires are all higher temp wires (125C/257F) like the good, striped split loom tubing.
Old Jan 20, 2022 | 02:58 AM
  #90
marksman76's Avatar
marksman76
Tonight I went out to my 01 F250 PSD, and I noticed my USB charger with temperature and voltage display showed 9.4 volts.
Well I had not run truck since Friday 1/14/22. I also noticed that my fake alarm flashing red light was not on. The little red light I buy has a limited life span guessing 50,000 hours.
So I assumed parasitic draw and possibly faulty red light.
I opened the hood and noticed passenger side battery, positive terminal was heavily corroded. I pulled off the vent caps and noticed the corrosion from positive terminal had seeped into the closest cell ( or seeped out of ) ?.
I had never seen that before in my 46 years of working on my own vehicles.
The reason I am including this info in this post is because I bought and used some battery cleaner, and battery terminal protection spray. I think I bought it at Harbor Freight with a new battery post cleaner.
So I am thinking this protectant spray sealed up around the terminal where normally corrosive gases may slightly seep out?
