Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
My truck needed to be more POSITIVE and ENERGIZED!
Old 02-10-2018, 03:54 PM
Sous's Avatar
Sous
Sous is online now
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
Talking My truck needed to be more POSITIVE and ENERGIZED!
Since I updated to a QuickStart 160 Amp alternator from an OEM 110 Amp, I needed to up my game in the positive cable department. The QuickStart alternator came with an additional lug on the case for the negative cable to run to the negative terminal, but nothing for extra positive cables.
List of materials/parts below.
Ford 3/6G terminal extension - https://www.ebay.com/itm/Ford-3G-6G-...72.m2749.l2649 (This method may or may not work for your application based on different under hood liners being installed. Please see the posts below for further clarification and explanation)
Two way fuse block -
Amazon Amazon
2x 175A fuses -
Amazon Amazon
2 gauge SGX wire - https://www.ebay.com/itm/SGX-2-gauge...72.m2749.l2649
Red wire loom - https://www.ebay.com/itm/1-2-Split-W...72.m2749.l2649
I already had black wire and loom for the negative run. I went to a local starter/alternator re-builder in order to have the eyelets/ends put on securely.
I did have to modify the terminal extension a bit in order to fit the way I wanted it to. I trimmed down non-conductive material that goes against the alternator which provides a much more secure connection.
Pictures are below of the progress so far. The driver side battery cable from the fuse block is about 8" too long and I don't like how it is sitting in the engine bay. I plan to take it to the local shop on Monday to have it cut down and a new eyelet put on it.
This should provide more than enough continuity for the B+ terminal on the alternator and help keep the alternator and batteries healthy for a much longer period of time.
Cable from fuse block to passenger side battery.
Cable from fuse block to passenger side battery. Driver side is missing due to it being too long.
Terminal extension, OEM B+ lug and fuse block connection.
Another side view of the fuse block from the driver fender area.
Another view of the fuse block from the driver headlight area.
Old 02-10-2018, 05:37 PM
jimjokjv's Avatar
jimjokjv
jimjokjv is offline
jimjokjv has a good reputation on FTE.jimjokjv has a good reputation on FTE.
Looking good.
I noticed that my alternator gets fairly hot. Its new and stock but definitely runs hot to the touch.
Old 02-11-2018, 07:09 AM
Sous's Avatar
Sous
Sous is online now
Thanks for the compliment. I hate leaving such a simple project so close to completion, but the shorter cable I am not happy with and it would bug me if I "made it fit". I hope to have it back together Monday or Tuesday after work.
I need to get a picture of the OEM alternator, but noticed that B+ post had some temperature related damage to it when looking at it closer yesterday. I cannot say how long the alternator had been on there, but it has been there for the 4 years I have had the truck and looks a lot older than that.
I plan to put some liquid electrical tape over the connection where the OEM B+ wire attaches to the fuse block. Might be overkill, but if the alternator and wiring stays in place for even just a year it will be worth the 30 seconds it takes to put the coating on it.
Old 02-11-2018, 07:17 AM
Sous's Avatar
Sous
Sous is online now
Snapped a picture of the OEM terminal.
Old 02-11-2018, 07:28 AM
DieselDenny
DieselDenny is online now
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Great job on the Grill and wiring Sous !!
How is your hood clearance with the lugs on top?
I just replaced my alt and it is very close with the standard lug.
Nice job!
Denny
Old 02-11-2018, 07:52 AM
pirschwagon
pirschwagon is offline
pirschwagon has a very good reputation on FTE.pirschwagon has a very good reputation on FTE.pirschwagon has a very good reputation on FTE.
By far, the MOST IMPORTANT connection in a D.C. System is the GROUND Wire.
I suggest, in addition to your up-grades, you add a (-) Cable (one size smaller than the (+) from the Alternator CASE to the (-) Post.
The benefit is Reduced heat, better performance, and longer life.
Old 02-11-2018, 07:53 AM
Sous's Avatar
Sous
Sous is online now
Nice job!
Denny
The clearance was a concern of mine as well. I took a lot of extra time and even put pieces of paper taped to the underhood liner to make sure there was no contact. In the end, there is easily 2" or so between the top of the lugs and the hood liner. Even then, there is a hard rubber cap (as seen in the picture) that goes over the lugs.
This was not my original mounting method for the fuse block, but the only one that would work for my application.
EDIT: So, in order to triple check the height, I "acquired" some lipstick from my wife and put some on the top of the red rubber cover for the lugs. The lipstick left no residue on the underhood liner. In addition, it looks like the top of the air box of my AIS is right about level with the top of the lugs.
I can cut down the lugs a 1/4" or so if I really can't sleep thinking about it, but don't think that is necessary at all.
Old 02-11-2018, 08:08 AM
Sous's Avatar
Sous
Sous is online now
Done sir! You may have missed it, but in the original post I mentioned that the QuickStart alternator came with a lug on the rear of the case for a negative cable to go to the driver side battery. You can actually see the negative cable in black loom in most of the pictures. It is the one that doesn't look right. It is not secured in any way because I wanted to make sure the positive cables are in place and secured before looking at ways to safely route the negative cable.
In addition, I already cleaned and re-secured the major ground connections on the block when I installed the headlight relay harness a year or so ago.
Old 02-11-2018, 12:41 PM
Colorado350's Avatar
Colorado350
Colorado350 is online now
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
Looking good Sous. I did the same thing but I used 4/0 cable from the alternator to passengers side fender well, mounted a 150 amp fuse then to passengers side battery. I ran a 4/0 cable to the drivers side battery too. I grounded the alternator with a 2/0 from the mount to the frame. I'm looking forward to seeing how this mod affects long term battery life. s
Old 02-11-2018, 12:59 PM
pirschwagon
That Engine Bay Looks GOOOOOOOOOOOOD! I never got to work on one like that! Most I pressure washed before doing the Job.
Old 02-11-2018, 02:44 PM
Sous's Avatar
Sous
Sous is online now
Thanks for the compliment, but I thought it was dirty due to my OCD. I almost didn't post the pictures because I haven't had a chance to clean it well this winter.
Old 02-11-2018, 03:46 PM
coax9952's Avatar
coax9952
coax9952 is offline
Athletic Supporter
coax9952 has a very good reputation on FTE.coax9952 has a very good reputation on FTE.coax9952 has a very good reputation on FTE.
Hey Sous, I can't really tell, Does that Fuse Block kinda just sit on top, self-supported by the Post and riding on a flat on the Alt? or is it an illusion thanks to your exacting detail?
Old 02-11-2018, 05:55 PM
Sous's Avatar
Sous
Sous is online now
I admit the pictures make it hard to see how the fuse block is situated over the alternator. It is well supported by the B+ extension, but again my OCD kicked in and said I needed to modify it a bit. There was a ring base at the bottom of the screw on top of the extension where the fuse block is installed. I welled out the fuse block mounting surface just enough to fit around that ring base.
This made the fuse block even more secure and it did not move at all. The bottom of the fuse block is non-conductive material, so even if I put my foot on the block while standing on it and the base of the fuse block hits the alternator while the truck is running, nothing will happen. Just to make it a bit more secure, I had some hard rubber strips with adhesive on one side, if you look closely toward the front of the fuse block you can see them squeezed between the alternator and the fuse block. This provided even more support for the fuse block.
I plan to post up some completed pictures this week once it is done. It really kind of irks me that I was that far off on the measuring of the cables, but so be it.
Old 02-11-2018, 07:41 PM
Colorado350
Sous, you're not worried about the heat of the alternator affecting the fuse block or melting the material or rubber you added? The alternator does get very warm/hot when running. Just something to consider...
Old 02-11-2018, 07:57 PM
Sous's Avatar
Sous
Sous is online now
I plan to keep an eye on the hard rubber I put on the bottom of the fuse block and simply remove it if I think it is a problem. The fuse block sits about 5/16" above the alternator in the shortest part and the entire bottom of the fuse block is a hard ceramic or something.
Once I get the wires secured, I will see if they prevent or promote movement of the fuse block in anyway. If they help secure it, I will probably remove the rubber stopper and leave the air gap so that heat will not transfer from direct contact to the fuse block.
If this does not work, I will figure something else out for the fuse block and clock it a different direction or something, but this is the best I could come up with so far. I originally wanted to mount the fuse block vertically behind the alternator, but the CAC was uncomfortably close to the lugs/B+ terminals.
Quick Reply: My truck needed to be more POSITIVE and ENERGIZED!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
