Upfitter Switch Question
Old Dec 28, 2021 | 11:43 AM
mma1's Avatar
mma1
Trailering
I have a 2018 F250. I have the Morimoto headlights. I want to hook the daytime running lights to the upfitter switches. There is only 1 red wire. Do I have to ground it somehow or is it ok to hook the wire directly to the upfitter wire with no ground?
TIA
Old Dec 28, 2021 | 12:19 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Do those headlights have a separate DRL in them?
Otherwise, I would think you may get a backfeed from running a new power supply into the headlight circuit, could screw things up.
If the DRL is a separate light, then just run the upfitter wire to the hot lead you found, but it needs to be separated from the rest of the light harness.
Old Dec 28, 2021 | 12:42 PM
mma1's Avatar
mma1
Trailering
The headlights do have separate DRL lights and a separate wire. Its just one wire without a ground so thats why I am confused.
Old Dec 28, 2021 | 02:05 PM
Zchludil's Avatar
Zchludil
TIA
Yes, you can do that. I have a 2017 F250 that I was having all sorts of problems with my Morimoto DRL going to the fuse block, so I just hooked that single wire to aux 3 and haven’t had a problem since then.
Old Dec 28, 2021 | 06:07 PM
75Mike's Avatar
75Mike
https://www.ford-trucks.com/forums/1...l#post20082012
Old Dec 28, 2021 | 07:48 PM
4B11TX's Avatar
4B11TX
I just hook the drl wire to my upfitter and it works great.
Old Dec 28, 2021 | 08:09 PM
mma1's Avatar
mma1
Trailering
Thanks everyone.
B846B
Feb 1, 2013 04:04 PM
Dominating
Sep 17, 2012 05:17 PM
WA_PSD
Feb 2, 2012 10:09 PM
F15090300
Electrical Systems/Wiring
Jan 10, 2005 07:43 PM
Brizzadd
Apr 1, 2003 10:25 AM
