I own a 1996 EB Bronco. I bought a set of indiglo gauges for it and I'm having a little trouble wiring them up. They only have 2 wires to hook up, red for power and black for ground. I got the black one grounded but I can't find out which wire on the back of the headlight switch the red should go to. I want the gauges to come on with the parking/headlights. I halfway have them hooked up right now but they won't turn off even when the headlights and ignition are off. Anyone know which wire I should hook the red wire up to so they'll turn on/off with the headlight switch?
The parking lights are the brown wire off the headlight switch. The LB/R wire comes off the dimmer, but I don't know if Indiglos work on less than 12V.
The kit comes with it's own dimmer. I have no blue w/ red stripe wire. Right smack in the middle is a tannish greyish wire about 3 times the size of the others.
