5-8 seconds to start?
If it is good, then move to checking the glow plugs. You really have pretty low miles for an '03, but it still has the years on it.
When you turn the key on, the GPR turns on. The WTS light goes out in a few seconds, but the GPR remains active for up to two minutes.
If you measure battery voltage before turning the key on, you should see about 12.6 volts. When the GPR is active, the glow plugs draw a lot of power and your battery voltage will drop about a volt. Lets call it 11.7V for discussion.
So on the big "always hot" GPR lug measured to ground, 12.6 before key on and 11.7 with key on.
If the GPR is good, you should see 0V on the big switched lug before key on, and almost 11.7V with the key on.
Now lets assume the GPR is weak... It does not make a good solid connection between the two lugs. Mine dropped 6V but for discussion let's assume it drops 3V... So the always hot lug might read about 12V when the key is on, and the switched lug will read 9V. So there are two things going on here... The battery voltage did not drop as much as it should since the GPR is weak and the glow plugs are not drawing as much power as they should. And the other thing is the switched lug voltage does not match the always hot lug.
So now to the example in the youtube video measuring across the GPR... A good GPR will have a small drop, maybe a tenth or two. But in my example in the previous paragraph, the drop is 3V.
That 3V is enough to call the GPR bad, but lets now pretend you saw no drop when it is active... Does that mean the GPR is good? It could be, or the glow plugs may not be connected to it at all. That earlier test showing the 1V drop in battery power (12.6V dropping to 11.7V when the GPR is on) indicates the glow plugs (at least many of them) are drawing a lot of power.
So the shortcut test across the relay can confirm the relay is bad, but not that it is good. Hope this helps. There are some additional tests to look at the glow plugs, but I think the above is enough for the moment.
