Tire Chain BS(?) Alert for SD
https://fordauthority.com/2021/12/ce...e-snow-chains/
Certain Ford Super Duty Trucks Cannot Use Snow Chains
Have to say I am irritated. This article might as well be on FB. We live far remote up, and I do mean up - some 20% grades with no way to get a run for it, 2 miles of rough logging trails. When we use chains it is <10 mph and crawling. Could be chains just on the back but just as easy all the way around. I can find no precautions in the owner's manual about tire "chains" cable or otherwise. Specifically, we only use Laclede V-Block cam lock with their rubber tensioners. The above gives mention to "cable" chains and is misleading. To me there is no such thing as a cable chain. Its either cable or its chain.
The article references clearance. Again, BS. Our lowest rig is a 2000 F250 Off Road and I've run the V-Blocks on it for years. The wife has a newer F250 that is higher and mine is a F350 and both have V-Blocks in the tool box. Never a problem. But duh, when we get out of the canyon the chains come off. We would not go to town on the highway at 20mph. Duh.
OK, I'm done.
OK, I'm done.
You, personally might not leave the chains on but others… Gotta remember, lawyers require companies to dictate rules for the lowest common denominator. Think of the dumbest person you know and then imagine rules being made for the idiots on the other side of them.
It’s why I can’t have M80s anymore. A couple people blow their fingers off and suddenly I can’t have fun either…
The following users liked this post:
Received 6,776 Likes
on
OK, I'm done.
OK, I'm done.
Note: Do not use snow chains on vehicles with 20 inch wheels and tires.
I have the 18" wheels. I use both cable chains and the heavy duty ladder type chains. When conditions aren't too bad, I use the cable chains. Deep stuff or if I'm towing, I use the ladder type chains.
Aside from the prohibition on 20” tires, my 2020 SD owners manual pg. 408 also directs you only use Class S (cable) chains and only on the rear axle.
I’ve used cables on our much lighter SUV but seriously question their effectiveness on the SD with camper on unplowed backcountry roads. Please keep your real-world experiences with chains or cables coming as I want to get a set by January.
It really depends where you are going. You aren't going to be bringing a rig like that into our conditions but, eh, you could. Frankly, if I was in your position, I would carry both. The cables work just fine in a lot of stuff. Use the heavy chains in the really bad spots. Neither work well if you are already stuck. So you wonder: 'Which ones'?
Cables don't pack well. A kitty litter plastic box works great for a pair of chain chains. Just drill a few holes in the bottom. I don't own any cable traction devices. But I have a bunch of cable to pull people out of ditches.
I've used the V bar chains on all my Superduty trucks with 18" tires with no issues or damage. They key factor is proper installation and practice putting them on first in perfect conditions before attempting to wing it for the first time in a storm or adverse conditions. Having a small tarp to kneel or lay on while attching the chains help some from getting soaked from snow.
I also carry these in all the trucks when just a little help is needed and not wanting to put the full wheel chain on.
Disregard the manual, use common sense and make sure the chains fit and clear anything you don't want scratched or ripped off. I too run Laclede V-bars with cam locks on all 4, excellent chains and nothing like a V-bar for traction. Never used cable types so can't say how well they work. I've never used tensioners either but my friends do, may try them some day.
Titan chains on eTrailer
Common sense is no longer common in America and the big picture is no longer in the picture. With that said if you are one of the majority in this country that fits into those categories and chains are needed or required you need to stay off of the paved and dirt roads. You are a hazard to yourself, others, and your vehicle. You give people like myself and the others posted above me the joy of pulling others back onto the road . (You can quote that first sentence) Rant over.
I always trial fit as suggested above. I cut my chains to fit. On the inside of the wheel I cut to the exact fit not one link extra. On the out side I leave 2-3 extra links to help get latched. Then I drive 2-3 tire rotations and adjust any slop out and apply bungees/tensioners of your favorite style. With the re-adjust I attach a bungee hook on to the loose 1-2 links to keep them from flinging around I came about this process with common sense over a few years and then 40 plus years of following the same process on many different vehicles. This process works. But having common sense is the most important issue. Stop and investigate if you hear a sound you do not like, repair or remove the chains.
The following 4 users liked this post by JDski:
We also live in a remote area, 3-1/2 miles off the nearest pavement where our mailboxes are. Mail is delivered only 3 days each week. Several hills, steep grades. One stretch is nearly a mile of winding, varied grade in a canyon that gets hardly any sun during the winter season. Once a few people drive on it, snow quickly becomes packed snow, then ice. 90% of us haul water since drilling a well is a 600'-900' proposition with only about a 30% chance of hitting water, then only .5 - 2 gallons per minute.
Without chains, none of us would be getting in or out of the 'hood for weeks or months at a time. Yes, we drive slowly, even in dry times since we all have to pay to maintain the roads. Once we get to the pavement, chains come off.
Funny how the auto manufacturers seem to have lost connection with what trucks should do. Not just get shiny bits thrown on and looks good at the mall.
I like JD fit my chains every time a different set of tires goes on the truck, once a season usually. I run bar chains on 35" Tremor sized tires (285/75-18) with no problem. There is more than enough room for them front and rear. You have to watch full lock in the front because mine start clicking the radius arm but. Making a "no chains" statement is just for the lawyers and idiots that surround us. It is my truck and I'll run chains on it as needed. I sure do not need Ford permission or anyone else's for that matter.
I've used the V bar chains on all my Superduty trucks with 18" tires with no issues or damage. They key factor is proper installation and practice putting them on first time in perfect conditions before attempting to wing it for the first time in a storm or adverse conditions. Having a small tarp to kneel or lay on while attching the chains help some from getting soaked from snow.
