Tire Chain BS(?) Alert for SD
I've got all my chains from here.
https://tirechain.com/emergency-tire-straps/
I should note that I use 2 per tire to releave the spin/ grab of the chains.
The following users liked this post:
That may be so that you can put a full set on faster but from personal experience I'd rather throw the emergency chains on for getting up an incline that's iced over or getting out of a mud slick area than fooling with a full set especially with my dually which has the dual chain per side.
That may be so that you can put a full set on faster but from personal experience I rather throws the emergency chains on for getting up an incline that's iced over or getting out of a mud slick area than fooling with a full set especially with my dually which has the dual chain per side.
No more dangerous than a full set. Keep in mind these aren't for long drives like a full set, these are for short needs like I posted without the hassle of an entire wheel wrap. I think you're picturing a long haul ride with them.
The notice seems to be "common sense." Which, unfortunately, ain't very common for the last couple of decades and won't get any better at the rate we're going.
Kind of like the alarm that goes off on my F250 to tell me to check the back seat (so I don't forget my kids are there? Come on. If you can't remember your kids are in the back seat, you shouldn't be allowed to drive.)
Chains are very useful and sometimes the only way you can get where you want to/need to go.
I used to need them every now and then when I lived in the mountains (rear wheel drive cars). I remember when they used to come in cloth bags you stored them in your trunk in all winter - just in case. Be a pain in the butt for me to have to put some on the new truck these days.
Corporations and lawyers may be more dangerous to our future than the government.
May your chains always work and never break. Or something like that.
on
The following 2 users liked this post by arniet:
When I need chains (real chains. Vblocks, not cables) these would be a problem. But like no chains at all you don't know until you are in the $h1T unless you think forward..
My worst nightmare is climbing the grade, even with previous tire tracks and having the wheel hop happen. If you slow down you are screwed and you can't speed up. You can't get a run for it so ya have to power through it, tolerate it, and wonder how many years of life you lost to a bunch of drive train trauma. If ya don't break something immediately. With these strap on chains I'd never get home.
Full, tight, Vblock chains protect against problems. Of course there is the philosophy that the better your traction is the worse you get stuck and I can verify that is true. But ya also need to know when to stop.
Received 6,970 Likes
on
Don, I had to buy a set of carabiners like that for my chains. They were specifically listed as "Tire Chain Extenders". They're probably the same exact thing you posted, just in different packaging. The Laclede chains are the right ones for my tire size, they just won't go on without either airing way down (< 40 PSI) or adding the extenders.
#28
On the big crude haulers, I would chain both drive axles generally with full dual chains, have one for a tire on the steer axle if needed, and at least two for drag chains on the trailer when it got real bad. And at 110,000 pounds + with 600 HP it was easy to tear them up! Field repairs happened quite frequently.
#29
on
And probably charge more than for regular hardware! But, they make great emergency repairs in the field, quick n easy. I always had two or three sizes of the also. Just in case.
#30
