IPR
Old Dec 3, 2021 | 11:26 AM
smitty59's Avatar
smitty59
I got the ICP sensors at ProSource Diesel and the IPR on Ebay which I think is counterfit!
Old Dec 18, 2021 | 07:01 AM
smitty59's Avatar
smitty59
So come to find out that Ford, in it's infinite wisdom, changed the IPR connector without even telling it's parts people. The connector on the IPR changed and they changed the pigtail. Imagine that!
Old Dec 18, 2021 | 07:23 AM
ESwift's Avatar
ESwift
CNCFAB
Do they want you to use a pigtail like this?
Old Dec 18, 2021 | 08:33 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Hasn't there been two types of IPR connectors and pigtails available for quite some time? I "think" I remember this from years ago when I sent a wire clip style pigtail to someone attempting to dead head their HPOP and needed the pigtail to close the IPR.
Doing a bit more "light" research I found the following...
Originally Posted by Riffraff Performance
​​​​​​​Engine Serial Number Info:
187100 and up take F81Z9C968AB
187099 and below take 2C3Z9C968BA
I am sure you need an F81Z9C968AB but if you want to make sure pull your pump and post up a picture of the front of your pump mounting surface and we can just by referencing it.
Quote source - https://www.ford-trucks.com/forums/1...l#post18484665
For posterity sake...
IPR 2C3Z9C968BA
IPR F81Z9C968AB
I hope this helps.
Old Dec 18, 2021 | 09:05 AM
Walleye Hunter's Avatar
Walleye Hunter
If Ford doesn't have the right one, can't it be obtained from Navistar?
Old Dec 18, 2021 | 10:04 AM
duck fan's Avatar
duck fan
Because racetruck
Ford hasn't changed the IPR, but the did update the pigtail to the more secure attachment style about 10 years ago. My bet is that it is a counterfeit IPR sensor. The best way to get good parts is to buy directly from Ford and pay high prices or use a Reputable shop like @Riffraff Performance that only sells genuine parts. Here are some links to the new and the old pigtails, as well as to the ICP and IPR. Stay away from places like Amazon, eBay and Prosource if you want genuine parts.
https://www.riffraffdiesel.com/allia...air-kit-94-07/
https://www.riffraffdiesel.com/ipr-i...gulator-96-03/
https://www.riffraffdiesel.com/injec...-sensor-97-03/
Old Dec 18, 2021 | 10:18 AM
ESwift's Avatar
ESwift
CNCFAB
For reference, I just opened an ipr package for this pic. I bought this a month ago. It is designed like they always have been.
Split rims
2011 - 2019 Explorer
Jul 5, 2021 09:35 AM
MK_snipe
Sep 23, 2016 10:16 AM
Zixxer
Mar 6, 2013 09:02 AM
1Knight
Sep 21, 2009 02:05 PM
IsItFast?
Nov 24, 2008 02:57 PM
