IPR
Old Dec 1, 2021 | 11:45 AM
smitty59's Avatar
smitty59
IPR
I bought a new OEM Ford Motorctaft part # CM-5013-1X. F81Z-9C968-AB. I got ready to install and couldn't get the connector to go on. After removing the solonoid several times to see what the problem was I noticed that the connector on the solonoid was upside down compaired to the original one on the truck. I bought the truck new so I know that the IPR has never been replaced. The truck has over 279k miles on it. I have changed the ICP and now replacing the IPR because the #'s were all screwed up and it quit running and the codes said that was the issue. I would like to ask can I just turn the connector on the truck over to match the connector on the solonoid or are the wires polarized (+ and -)
Old Dec 1, 2021 | 11:46 AM
smitty59's Avatar
smitty59
I don't know how to post pics yet.
Old Dec 1, 2021 | 11:50 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
I look forward to a photo, but I don't think it matters which wire is which.
Old Dec 1, 2021 | 12:23 PM
BWST's Avatar
BWST
Got Data?
We'd sure like to see what you are dealing with here. I would think the IPR connector would only go on the IPR solenoid upright - given the bail that snaps in place on top. I don't see how you could flip that connector over and still latch it. Is your IPR pigtail different from this?
Post pics by clicking the icon circled below:
Old Dec 1, 2021 | 12:25 PM
RacinJasonWV's Avatar
RacinJasonWV
Cant answer your original question but can help you with posting photos.
Use either of these buttons to get to your pictures. Find them and select “add.” They will load into a screen then you choose “upload” at the top right. At least that’s how it happens on my phone.
Welcome to the forum!
Edit: I’m too slow. BWST beat me to it.
Old Dec 1, 2021 | 02:18 PM
smitty59's Avatar
smitty59
timmyboy76's Avatar
timmyboy76
Lol....yes you can.
..just went thru this the other day. Fighting that damn pigtail for about 30min and finally HAD TO take a gander at the connector on solenoid. Sure enough, it's a complete 180* upside down...
Old Dec 1, 2021 | 05:14 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
This is good info to have, seeing as how I just purchased a fomoco IPR and have yet to install. I wonder if that’s an accident or how they are doing them now?
Old Dec 1, 2021 | 05:20 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
This one looks right
Old Dec 2, 2021 | 08:19 AM
timmyboy76's Avatar
timmyboy76
Yup..thats the original way
As for the original poster, not only will you have to flip the pigtail connector over but you'll also have to remove the metal latch and install it the other way...if not, you wont be able to clamp the pigtail shut, to the connector
Old Dec 2, 2021 | 08:58 AM
Walleye Hunter's Avatar
Walleye Hunter
Is the old magnet still good? I'd try reusing that.
Old Dec 3, 2021 | 07:51 AM
smitty59's Avatar
smitty59
Ok now I've replaced the ICP and the IPR and I'M still getting the 1280 code after 2 new ICP sensors!!!!! Any ideaas?
Old Dec 3, 2021 | 08:59 AM
Dmco's Avatar
Dmco
Where are you buying your parts? And are you sure they are genuine Motorcraft?
I purchased a Motorcraft ICP from Amazon and it failed with P1280 codes within a few months.
I believe it was a knock off part. Replaced it with a genuine part from my local dealer and noticed subtle differences in the packaging.
I wonder if the inverted connector could be related to knockoff parts?
If you are confident in your parts, I would suspect your wiring pigtails or something in the harness.
Old Dec 3, 2021 | 09:04 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Speaking to the point by Dmco above, it is getting difficult to spot a fake. A bit of background on that is in the link below.
Link: https://www.ford-trucks.com/forums/1...are-clues.html
Old Dec 3, 2021 | 11:24 AM
BWST's Avatar
BWST
Got Data?
That's more likely, isn't it? I have trouble believing Motorcraft would flip that IPR coil polarity like that.
