Dead again!!!!!!
Old Nov 18, 2021 | 05:02 PM
bismic's Avatar
bismic
Re-reading the thread ....
Trying to start with the IPR unplugged is a waste of time. Actually probably worse than a waste of time. The engine won't start and you will get codes that might mis-lead you.
Cranking with the crank sensor unplugged will most definitely throw the P0335 code.
Both P0611 and P1378 point pretty heavily at the FICM internals. Do you possibly have a spare FICM to run for a while?
For some reason Auto Enginuity can do some funny things. I like ForScan much better.
Old Nov 18, 2021 | 07:04 PM
LindenBruce's Avatar
LindenBruce
I wish I had a spare FICM. Will the FICM still put out 48-49v on the main side and still be going bad?
Will Forscan let me see the crank and cam sensors individually? B.
Old Nov 18, 2021 | 07:08 PM
bismic's Avatar
bismic
yes .
Old Nov 18, 2021 | 07:26 PM
IHateCommieCars's Avatar
IHateCommieCars
IDK anything, but 40% at idle isn't right.
Old Nov 18, 2021 | 08:04 PM
bismic's Avatar
bismic
There very well may be a leak in the HPO system. Even so, the main objective is to make sure the engine starts and doesn't die. From the data I have seen posted, I don't see the no-start being with the HPO system. JMHO.
Old Nov 18, 2021 | 10:16 PM
LindenBruce
Hum.... Gosh, I would hope there is not a leak in the HPO system. Everything is new. I was careful with reinstalling the oil logs. It has the updated dummy plugs and stand pipes. It has been starting right away when hot. I wonder if the ICP sensor is going bad?
The only thing to hint at a problem was Monday morning when I had that 15 second crank to start cold. The rest of the day it was normal. Then Tuesday it would not start at all. Nor would it start yesterday. The only thing I did this morning was re-install the crank sensor, check fuses and relays, and checked the LPO system. I did change the crank sensor pigtail last winter when I did the top end. All connections were soldered and heat shrinked. B.
Old Nov 18, 2021 | 10:30 PM
bismic's Avatar
bismic
IMO worrying about a leak is not necessary at this point. I base that on your first post where it wouldn't start with acceptable ICP pressure and sensor voltage.
Your data:
ICP PSI 1480-1680 during cranking
ICPR % bounces around between 14 and 66 during cranking
ICPV is steady at 1.4V during cranking.
The ICP volts are off a little from the typical voltage/pressure correlation, but still I would think it was sufficient for a start.
An important PID to watch when you have a no-start is the Injector Pulse Width. If the FICM is working, you should have a cranking value for that PID.
Old Nov 18, 2021 | 10:33 PM
LindenBruce
And those numbers come from AE. I think I will get the free Windows version of Forscan and get new numbers. B.
Old Nov 18, 2021 | 11:54 PM
LindenBruce
Well, I down loaded Forscan to my laptop. But, the AE adapter is not compatible. So I had to order an adapter and it will be here in one or two weeks. Jesus. B.
Old Nov 19, 2021 | 12:21 AM
Hartwig's Avatar
Hartwig
Try this.
Amazon Amazon
Old Nov 19, 2021 | 01:02 AM
LindenBruce
That's the one I did order. The other one is not available until early January. Thanks Hartwig. B.
Old Nov 19, 2021 | 04:58 AM
TooManyToys.'s Avatar
TooManyToys.
If you can swim, it's on the boat.
Old Nov 19, 2021 | 11:59 AM
  #28
LindenBruce
Sadly you are prolly right Jack. I can swim quite well, but prefer to be diving at the time. B.
Old Nov 19, 2021 | 12:48 PM
  #29
Motohead911's Avatar
Motohead911
B where you at, l know CA somewhere, I'm in Ventura County. I have both an obd adaptor and IDS.
NVM saw you are up north. PM I can over night you an adapter possible if needed. It does what with Torque, Forscan Lite, and Forscan laptop edition
Old Nov 19, 2021 | 08:05 PM
  #30
diesel_dan's Avatar
diesel_dan
Bruce I sent you a PM, but figured I should also put the link to an Adapter that I Know works with Forscan (in all modes), and is available delivered to me by the 22nd, and I'm an hour east of Sacto...
https://www.amazon.com/gp/product/B01N18TOFB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01N18TOFB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
