AT shift rod
Old Nov 7, 2021 | 09:17 AM
Restenhaus72's Avatar
Restenhaus72
AT shift rod
Looking for a '73 - '77 shift rod (goes from C6 shifter to shift lever @ lower steering column). It looks like this item is not available aftermarket. Does anyone know the part # for this item or have one laying around they would part with ?
Thanks folks !
Old Nov 8, 2021 | 07:53 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
All I got. #7326
Old Nov 8, 2021 | 08:55 AM
Restenhaus72
Thanks Dean, I found that part number previously but apparently there are several Ford auto shift rods with that designation from various car models. Just not sure if they would adapt to the trucks.
Old Nov 8, 2021 | 10:08 AM
dlburch's Avatar
dlburch
a couple references to the part number D3TZ-7326-A:
https://www.ford-trucks.com/forums/6...ml#post4725213
https://www.ford-trucks.com/forums/1...l#post12703797
apparently two in stock here:
https://www.rearcounter.com/D3TZ-732...ts1529398.html
Old Nov 8, 2021 | 10:34 AM
aldridgec's Avatar
aldridgec
What is showin in the parts diagram is not the full part number, just the base number showing what group it belongs to. You’d need the parts catalog listing for the full part number.
Old Nov 8, 2021 | 11:35 AM
Restenhaus72
dlburch, invaluable information. Thank you !
72CC428
Dec 7, 2018 08:25 PM
66_in_ky
May 6, 2010 09:25 PM
zswiss182
Jan 29, 2010 05:53 PM
ford390gashog
Apr 30, 2007 04:57 AM
