Codes p0340 p1211
Old Oct 14, 2021 | 01:05 PM
Hunter_d99's Avatar
Hunter_d99
Codes p0340 p1211
Got a early 99 with 495,000km on it. My truck has these hiccups while driving, it lose power for a second a couple of time around 80kph and when i let off to slow down to make a turn. It sometime shuts off. I plugged my code reader in and its saying that its my cps and icp.
I replace both sensors in June, where i was having the same problem before and after replacing both sensors the truck didn't have a problem until a week ago.
Im just wonder if its a wiring issue or something bigger
Old Oct 14, 2021 | 09:40 PM
udsuth78's Avatar
udsuth78
That is a likely assumption. The IPR connector is prone to wiring shorts and will cause the symptoms you've described. Considering both codes, the problem may be at the 42 pin where it rubs the valve cover.
Old Oct 15, 2021 | 08:13 AM
FordTruckNoob's Avatar
FordTruckNoob
Were the sensors replaced with genuine Ford/Motorcraft parts?
Old Oct 16, 2021 | 08:18 AM
Listor's Avatar
Listor
the boys there are correct, only genuine motorcraft parts, IPR pigtail can break down inside the harness ( likely from being twisted to realign)
same with the CPS and IPR
johnsps250
Dec 21, 2016 07:48 AM
green ghost
Dec 15, 2010 03:25 PM
kx450frider617
Apr 13, 2010 08:21 PM
78f3504x4
Sep 3, 2009 11:04 AM
99f250
Jul 25, 2003 12:47 AM
