Cam Position Sensor Problem, and other code stored.
Old Dec 19, 2016 | 01:45 PM
johnsps250's Avatar
johnsps250
So it looks like the CPS that I have been carrying around in the glove box for over 12 years, along with the screwdriver and 10mm socket finally paid off over the weekend.
On a hunting trip about 1/2 mile from the property, truck running great bucked hard once and set a code, SES lit. Another 1/4 mile down the road, it bucked harder and shut off. I coasted to a stop at the entrance to the property and was greeted by a cloud of unburnt diesel as I opened the door to get out. Tried to restart and it wasn't going to happen.
AT that point safely off the road, I unloaded the atv and went hunting. When I returned several hours later, turned the key got the wait to start along with the glow plugs and fired off like it never happened.
When I got back to a friends house I let it run, and it stalled within 15 minutes SES lit again.
With no way to read the codes, I figured the only thing I was prepared to do was replace the CPS. Truck ran fine the rest of the weekend after I replaced it. Got home Sunday afternoon scanned with AE and had 2 CPS codes stored, PO340, and PO344.
One other code that stored was B1352 Ignition Key in Circuit fault. I've done several searches, a ton of reading, and have been unable to find a definitive answer on what this is or if anyone has been able clear it and keep it from returning. My door chime is intact and working etc.. Although I don't think it had anything with my weekend problem any input would be appreciated.
On another note, I now have an android tablet/scan tool that will live in the truck. AE and a laptop 1.5 hours away was, and is worthless!
Old Dec 19, 2016 | 06:45 PM
F350-6's Avatar
F350-6
Clear all the codes and move on. Odd codes pop up when troubles start that don't indicate anything. If the CPS was the issue (which it sure sounds like it was), then ignore the ignition code thing and move on.
It's what's called a phantom code. Those are the reason so many suggest clearing all the codes and driving to see which codes come back. That can keep you from chasing your tail diagnosing things.
Old Dec 21, 2016 | 07:48 AM
johnsps250's Avatar
johnsps250
Thanks Chris,
That one has actually been showing up for quite some time. I suppose its possible that the CPS has been on the way out for a while. It sure seems to idle and run smoother now.
I will trying scanning in a few days and see if it comes back.
Justin03PSD
19
Apr 6, 2022 11:45 AM
green ghost
Dec 15, 2010 03:25 PM
mustangless
Oct 12, 2007 07:20 PM
Mikeysnapper
Mar 3, 2007 11:48 AM
99f250
Jul 25, 2003 12:47 AM
