pcm trouble
Old Oct 12, 2021 | 02:20 PM
morrisonjeff's Avatar
morrisonjeff
pcm trouble
ive got a 1997 f350 7.3 powerstroke 2wheel drive automatic. im getting p0603-pcm processor keep alive memory (kam) error.
ive read up that i need to replace pcm but when i look to purchase a pcm it gives several different callibration codes like 7-89n or 7-90p or 6-89s or module id# DCP-203 or module id# DCP-202...
how do i figure out what i need ?? please help
Old Oct 12, 2021 | 03:35 PM
Edgethis's Avatar
Edgethis
You'll probably have to pull the actual pcm you have out to read the codes on it.
Old Oct 12, 2021 | 07:06 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If you have FORScan or FORScan Lite you can read the box code without physically removing the PCM.
If you are not familiar with FORScan or FSL, there are details about it in the 7.3L PSD Tech Folder.
Old Oct 13, 2021 | 07:45 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Auto will be DPC-202 .
Chipped? If so, that's causing your code. Also P0603 isn't a real problem...it won't cause any driveability issues.
Old Oct 18, 2021 | 11:07 AM
7.3PS95's Avatar
7.3PS95
4wd Low
I chipped my 95. I got the code before I pulled my PCM by sticking my phone between the PCM and the fender and taking a picture of the side of the PCM.
Give it a shot (or 5) and it might work for you, too.
I've seen several OBS models in the local junkyard here with PCM's that look unmolested... Depending on the yard, there may be a 30 day warranty, so the $20 for the new to you PCM isn't at risk.
Tabiks
Jun 1, 2021 11:46 AM
luny1
Sep 16, 2011 12:49 PM
cornutsoffroad
Nov 1, 2008 01:34 PM
Rino Onir
Nov 10, 2007 11:20 AM
johnimpact
Feb 5, 2004 11:48 AM
