p1000,p1636,p063,p0670 codes
P1000 N/A OBDII monitor status OBDII monitors/drive cycle incomplete.
This means not enough drive cycles for accurate info.
P0670 GPCM Glow plug control module control line failure Open/grounded circuit, open/shorted GPCM, failed PCM
Self explanatory. Check all the connectors to the GPCM.
P0603 PCED Internal control module KAM error Open PCM pin, disconnect B+, faulty PCM
The P063 was most likely a P0603 and is usually caused by removing power from the PCM. Removing batt cables or removing PCM will give this code.
Didn't find P1636 on my list.
I just did a google search and found this:
P1636 FORD - "Inductive Signature Chip Communication Error" (??)
I'm waiting for my Ca. emc2 pcm to get back from PHP. I had them set it up stock to run my single shots.
The chip I have in the pmt1 I'm running now is set up for the Ca pcm.
I think once I get this chip in the ca pcm all should be well.
I just wanted to make sure the codes were nothing real serious.
Jmudweiser
09-13-2016 05:02 PM
rolltide3006
20
06-24-2013 09:01 PM
Haines Hooter
02-25-2013 05:48 PM
John7894
04-01-2007 03:40 PM
JDracer
Computer Chips & Tuners
08-05-2004 02:08 PM
