7.3 Missing / Hiccuping
Old Sep 29, 2021 | 09:25 AM
soggyburrito's Avatar
soggyburrito
Hoping to find some helpful advice here as I am new to the 7.3.
I have a 1997 7.3 and I am having an intermittent "miss" problem. Typically worse when the motor is cold, but the problem remains after heated up as well. (No CEL or Codes)
When its acting up it has a noticeable bad stroke that feels like completely dead cylinder, followed by a knock, and then goes back to normal. Problem is worse on acceleration, and the issue comes and goes.
So far I have done an oil change with hot shots stiction eliminator, CPS ICP, IPR, Cleaned fuel bowl, starting to suspect UVCH or IDM, but wondering if it could be Injectors or Injector O-Rings.
***SOLVED***
After a couple months of trying what seems like everything on this truck, we installed ANOTHER new CPS (Black with Purple O ring this time) and the problem was resolved.
The only thing we can figure at this point is that the CPS was sending incorrect signals and causing the random misfire.
Old Sep 29, 2021 | 09:54 AM
farmert's Avatar
farmert
Check the wiring harness to the valve covers for melting and/or burned pins. If one shows signs of overheating, the miss will get worse, and may even lead to one bank shutting down. Do you know how many miles on the injectors?
Where are my manners, Welcome to the best forums on the net for these old trucks.
Old Sep 29, 2021 | 10:53 AM
soggyburrito
Hey, thanks for the reply and the welcome! I did check the wiring on the passenger side but could not see the harness on the driver side to check for bare spots...
As for the injectors I have no idea, I swiped the truck on the backside of a dealership trade in thanks to guy I know. The truck has 339,000 on the clock and with this strange occurrence aside runs great.
I imagine that nearing 350,000 the injectors have been replaced at least once already.
Old Sep 29, 2021 | 12:42 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
How are you checking for codes??? FORScan is pretty much the standard. Most of the readers you can purchase a the corner store do not read the truck properly.
Also just because you do not have a light does not indicate no codes.....
Old Sep 29, 2021 | 02:23 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Could be IDM, wiring, non FoMoCo sensors or injectors. At 350K it's 50/50 if the injectors have been charged, or changed with a quality product. Even a quality product can be abused. It's not uncommon for people to dump vehicles with known issues at a dealership vs selling private party.
Old Sep 29, 2021 | 05:57 PM
97-psd's Avatar
97-psd
You need to unplug the connectors to check for burnt pins.
You can also unplug IDM connector and use this test with a simple multi-meter:
https://www.ford-trucks.com/forums/a...6&d=1564842340
Old Sep 30, 2021 | 08:24 AM
soggyburrito
Thanks for the reply, using a Snap-On SOLUS to check for codes.
Old Sep 30, 2021 | 08:53 AM
soggyburrito
I was thinking it could be the IDM too... all the sensors I changed are Motorcraft from the dealer as well. Still unsure on the injectors, suppose I could pull them to see what shape they are in, but they sound good on the buzz test.
I knew the truck had an issue when I bought it, and for what I paid I could put a reman engine in the truck and it would still be a good deal for me.
Old Sep 30, 2021 | 08:56 AM
Bitterroot Diesel
Former Vendor
The buzz test doesn't do much more than check the signal from the IDM.
Old Sep 30, 2021 | 09:03 AM
soggyburrito
Thanks for the Link! Ill run this test later today.
Old Nov 4, 2021 | 08:22 AM
soggyburrito
Zach Fletcher
Oct 26, 2020 04:28 PM
Specializer
Mar 10, 2020 01:19 AM
chris thompson
Aug 2, 2017 01:20 PM
stirling35
May 16, 2017 11:33 PM
farmdad
Jul 13, 2010 08:04 AM
