Replacement radiator....
Old Sep 16, 2021 | 04:15 PM
Theboneskes's Avatar
Theboneskes
My stock radiator is starting to leak at a seam, so I'm looking for a good replacement that isnt a gazillion dollars! I see Rock Auto has 2 of them around $225 to $250 which is fine with me, but looking on the internet some ger very pricey! I've seen upwards of $600 to $700. I want a good replacement, what have you guys used? I want something good, I see 1Aauto has one for around $250 too, any good?
Oh, I have a 2003 Excursion 6.0
Thank you!
Old Sep 16, 2021 | 04:37 PM
IHateCommieCars's Avatar
IHateCommieCars
When do you want it? I ask because if you order it online the first 5 or 6 you get will be damaged by the carrier. Is the seam between the plastic and the aluminum? If so, you may get a radiator shop to re-crimp it. Or, if it's in the plastic itself, you can order upper and lower tanks and get a shop to replace them for you.
Old Sep 16, 2021 | 10:02 PM
joe blow's Avatar
joe blow
Buy once cry once is my motto. Performance radiator 2944
The same rad that BPD offers but you can get it direct. As commieCars mentioned, you will have a few damaged especially by UPS. My first two looked like the baggage handlers from an airline loaded it.
The 3rd had superficial damage and was usable. That piece was delivered by DHL after performance radiator had to take 2 back.
Old Sep 16, 2021 | 11:49 PM
LindenBruce's Avatar
LindenBruce
I've had good luck with stuff from RockAuto. But, if you are that concerned about the shipping, just go to your local Ford dealer and order direct from them. B.
Old Sep 17, 2021 | 12:00 AM
Theboneskes
I never thought about issues with shipping before, I use Rock Auto alot, just didnt know what other options are out there for radiators that wont bend me over!? I've bought alot of larger heavy stuff that's been shipped and havent had a problem, yet? Was just asking for other alternatives. Thank you!
Old Sep 17, 2021 | 06:17 AM
jsm180's Avatar
jsm180
I bought a Motorcraft from White Bear Lake several years ago, came UPS and was in perfect shape. I have heard they quit shipping them since then. Around here, FedEx does a better job at delivering boxes undamaged.
Old Sep 17, 2021 | 07:47 AM
TxMav's Avatar
TxMav
I bought mine from Performance radiator. First one leaked. They quickly replaced it, no delays or questions asked. The 2nd radiator has held up well.
Old Sep 17, 2021 | 08:40 AM
marker223's Avatar
marker223
My local Ford dealer has always had the radiator I need in stock and there is a core charge/refund for my old one.
2006 6.0 F250
Old Sep 17, 2021 | 04:39 PM
FiveOJester's Avatar
FiveOJester
As Jack pointed out to me, Rockauto sells the stock radiator for a reasonable price of $342. That's the way I'll go as I haven't heard of any aftermarkets that have the fins/inch & flow channels as the stock one. I run my truck hard towing during the summer and want as much radiator as possible.
Old Sep 17, 2021 | 10:14 PM
highboy1975's Avatar
highboy1975
My performance rad does what it should do. I had an early mishimoto and it was junk, didnt cool well at all, but i cant comment on the newer one. The ipr big one is very tempting though.
Old Sep 27, 2021 | 08:21 AM
SmackDaddy's Avatar
SmackDaddy
Mishimoto does well in Texas heat
Old Sep 29, 2021 | 12:52 AM
Yahiko's Avatar
Yahiko
The big issue with the Ford ones is they for some stupid use the shelf box to ship it in and not a good shipping box.
Old Sep 29, 2021 | 07:01 AM
TooManyToys.'s Avatar
TooManyToys.
Over the counter, not an issue. But every retailer shipping any radiator, I think, should have a stronger cardboard over-box for these.
Old Oct 2, 2021 | 11:52 PM
SmackDaddy's Avatar
SmackDaddy
You should see how Mishimoto packs theirs!
Old Oct 3, 2021 | 03:40 AM
Yahiko's Avatar
Yahiko
Plastic wrap and used TP?
