FL1995 vs FL1995–A
I think the difference was the gasket.. the old one was not flat.. it had a bit of a angle to it.. if i remember correctly.. the A is a flat gasket..
I fill it to top and that soaks down to like 1/2 and put some clean oil on gasket as well. I take a rag adn clean teh underside of the mount getting it all clean,, run the filter up by hand till it hit the mount then a 1/2 turn,, loosen and re tighten to hand tight, back it off and re tighten to hand tight with one hand much as i can turn it without going Hulk on it. that usually is no leak and able to double hand remove next time.. also put date and miles at change on bottom.. then mark my oil change tag on windshield with 5K for next change.
https://www.napaonline.com/en/search...995&referer=v2
I am ordering from rock auto tonight,
this is just plain crazy
here is a link to my Server for the comparisons
https://mega.nz/folder/7ZJDQQiT#tvNUKl9e_k7Ve4UebFVy_Q
the WIX 51515 is the wrong thread size, and not enough GPM to handle the 7.3L engine
https://www.autozone.com/filters-and...6xl/663672_0_0
buck cheaper than rockauto and no shipping,
cost me a meal out with my daughter though, so there's that.
might as well get two of them, prices are just going up the wall.
