7.3 Performance
Old May 20, 2003 | 04:29 AM
wwsjr's Avatar
wwsjr
7.3 Performance
I'm going to be pulling a 9000lb camper through the Rockies in about two weeks. How should I expect the powerstroke to perform and will I have any problems going up the mountians?
Old May 20, 2003 | 05:06 AM
alanscott's Avatar
alanscott
7.3 Performance
Tell us about your truck, is it stock? have you installed any gauges?
Old May 20, 2003 | 05:23 AM
wwsjr's Avatar
wwsjr
7.3 Performance
It is a stock 2002 F250 4x4. Nothing added
Old May 20, 2003 | 11:40 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
7.3 Performance
I have a better idea, you tell us how it performed, and we'll tell you how to improve on it.
It will do fine as long as you're not in a big hurry.
Old May 21, 2003 | 01:57 AM
SouthernDually's Avatar
SouthernDually
Smile 7.3 Performance
The only thing that I would say is to be careful of the hunting with the tranny.. also watch your temps..some of the hill will really work your engine. If you don't get in a hurry you should be fine. I know that I pull a little over 12000 and havn't had any problem to date. Of course I have made a couple of mods but just a few... Have fun and good luck.
Old May 21, 2003 | 12:42 PM
theologian's Avatar
theologian
7.3 Performance
I once grossed 24,600 lb going up Wolf Creek Pass, in the Rockies - that is as steep and long as it gets, and my powerstroke got hot, but managed fine. At one point on the climb, I would have felt more comfortable in low range, but we made it ok. Admittedly, my truck has a GCVW of 25,000 as opposed to your trucks GCVW of 20,000 lbs, but you should do fine towing 9,000 lbs. As others mentioned, do not try to get up the hill fast - take it easy, if you need to be in second, slow down, don't rush it, and you will keep everything cooler. With a stock truck, if you see plumes of Black smoke pouring out, ease up on the throttle a tad, to waste less fuel. Expect to be climbing hills at 30mph or less, and you will not damage anything. Try to get up at 45mph, and you probably will, but at the expense of your engine.
Check your oil levels every day, and add if needed. Make sure the coolant level is ok and ANY steam, stop and let it cool down. Take a few gallons of distilled water with you, just in case you need it.
Old May 22, 2003 | 04:14 AM
wwsjr's Avatar
wwsjr
7.3 Performance
Thanks for the advice.
I pretty much figured it would be a slow trip up the hills. I just wanted to hear from some else that had already done it. I was wondering without doing any expensive modifications would installing a 40hp chip help?
If so what kind and how hard are they to install?
Old May 25, 2003 | 10:14 AM
MrFeexit's Avatar
MrFeexit
7.3 Performance
Chips are way easy to install, the big and really important thing is to monitor your exhaust temps...too hot and bye bye turbo. I pull a very heavy job trailer and have no probs, but I am not in mountain country either. Flat central Wisconsin.
Old May 25, 2003 | 03:01 PM
Skeetshooter's Avatar
Skeetshooter
7.3 Performance
When traveling through the Rockies remember your 5k+ feet higher then sea level. I live in New Mexico and there is a substantial and noticeable loss in power at this altitude..
Jeff in NM …OUT
Some call it a six-pack, I call it a support group.
Old Jun 1, 2003 | 10:22 PM
flynavydiesel's Avatar
flynavydiesel
7.3 Performance
I pulled my 5k travel trailer through the Rockies and the Cascades last summer with out a problem. No power loss, tranny temp problems or bad milage per gallon. I got a stock F-350 no mods.
Sean
