Sponsored by: Real Truck
Cylinder Glazing
Old Sep 4, 2021 | 08:34 PM
JodyBryant's Avatar
JodyBryant
Cylinder Glazing
Good evening!
I have a 2006 F-250 with 185k. It’s at the shop in the process of getting head gaskets done. Once the heads were taken off the mechanic noticed that most of the cylinders have glazing/shiny at the top 1-2 inches.
Is this something I need to worry about? They are recommending putting a new motor in.
Thanks!
Old Sep 5, 2021 | 08:22 AM
Just Strokin's Avatar
Just Strokin
When a motor is first built,,, thye use a hone to "break the glaze" to hold oil until the piston rings seat and create this "glaze". Unless the motor was using oil or the heads show some cylinders are using old, I would not worry about it if you are not re-ringing the motor.
Old Sep 5, 2021 | 09:01 AM
JodyBryant's Avatar
JodyBryant
Thanks! I’ve only had the truck a month, it it was not burning oil at all. The mechanic feels it is from excessive idling or from the blown head gasket putting coolant into the cylinder.
Old Sep 5, 2021 | 09:33 AM
Slowpoke Slim's Avatar
Slowpoke Slim
Omg.
Please stop using that shop for ANYTHING.
If they're willing to spin that yarn past you, they're likely to try anything.
Old Sep 5, 2021 | 01:02 PM
HeavyDutyMechanic's Avatar
HeavyDutyMechanic
4wd High
Tell them to replace the head gasket, button it back up. Never go back to that shop. I mostly work on heavy equipment so I'm no Ford expert but IMO if this was really an issue I would start with new sleeves, pistons, rings... You don't need a whole new engine.
Old Sep 6, 2021 | 10:26 PM
senix's Avatar
senix
get away from them quickly and verify their work after.
Old Sep 7, 2021 | 09:51 AM
farmerfromkansas's Avatar
farmerfromkansas
Too bad these shops don't have websites where you can review their work, then others could check first before trusting these people to work on their vehicles. Maybe someone could create a website like Angie's list.
Old Sep 7, 2021 | 11:20 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Originally Posted by Slowpoke Slim
Omg.
You need to find a good diesel mechanic, not the place you're currently at. They don't know diesels.
nathan5603
1983 - 2012 Ranger & B-Series
Oct 5, 2008 06:35 PM
MikeMcCasland
16
May 24, 2008 05:39 PM
Jim59
Feb 20, 2007 02:31 PM
74f250sucab
Mar 3, 2005 11:30 AM
marnus
Aug 4, 2001 11:25 AM
