1969 Ranger
Old Mar 24, 2022 | 07:46 PM
  #46
cbrown9064's Avatar
cbrown9064
Awesome progress! I had no idea a CV had a frame, thought they were unit bodies...
Really looking good!
Old Mar 25, 2022 | 09:24 PM
  #47
Vabow's Avatar
Vabow
Purchased some hubcaps off of eBay, cut the center out of vic caps and urethane together.
what do you think?
Old Mar 25, 2022 | 09:29 PM
  #48
Vabow's Avatar
Vabow
My dad went over truck with the buffer and some compound. Also got tired of dealing with my old welder, picked up a new one.
Old Mar 26, 2022 | 01:02 AM
  #49
Obscure69's Avatar
Obscure69
Thanks for the clip, sounds great! Must be quite satisfying to be at this stage of the project!
Old Mar 26, 2022 | 09:23 AM
  #50
Vabow's Avatar
Vabow
Old Mar 26, 2022 | 09:59 AM
  #51
cbrown9064's Avatar
cbrown9064
Bitchin'
Are you gonna cut down the bed or make a flat bed? There was another recent thread on cutting down a 8' bed...
Old Mar 26, 2022 | 10:11 AM
  #52
Lrrr-RulerOfOmicronP's Avatar
How stiff is the frame? They did this on hot rod garage and if I remember right the bed and cab would hit from flexing. I do not have the membership to go back and watch the videos. I know Lucky really liked the truck though.
You really knock out projects!
Old Mar 26, 2022 | 11:22 AM
  #53
Vabow's Avatar
Vabow
Going to cut down the bed and install it on truck. The frame is definitely not as rigid right now. But I have watched lots of videos and most people weld supports from the rear can mounts to frame above axle. Once I get bed mounted and I will weld in some cross bracing.
Old Mar 26, 2022 | 05:51 PM
  #54
Vabow's Avatar
Vabow
Old Mar 26, 2022 | 05:54 PM
  #55
Vabow's Avatar
Vabow
Old Mar 26, 2022 | 05:56 PM
  #56
Vabow's Avatar
Vabow
Old Mar 26, 2022 | 06:03 PM
  #57
Vabow's Avatar
Vabow
Made mounts for gas tank, and some crossmembers to tie the frame together. Finished welding in the cab mounts and tied them into frame. Took it for a trip around the block everything is working good.
Old Mar 26, 2022 | 09:31 PM
  #58
Obscure69's Avatar
Obscure69
How thick is the material in the frame, and how does it compare to an original one?
Old Mar 26, 2022 | 09:33 PM
  #59
Obscure69's Avatar
Obscure69
was it Tony and Lucky that put some rubber mounts between the cab and the bed to tie them together and keep them from rubbing?
Old Mar 27, 2022 | 02:59 PM
  #60
Vabow's Avatar
Vabow
I started integrating the truck and vic wiring, used the factory f100 inj switch and some relays. I did not want to switch all the loads with the original f100 switch. It probably would have been ok but the vic has a 30 amp fuse and multiple wires. I ran two relays controlling the inj power and the factory vic fused power supply. This way it will be able to control any of the factory vic accessories.
